Metric certainly doesn't prevent imprecision or confusion. The metric system you have been touting, the self consistent and easy set of units has NOT been tried and tested for over two centuries. Although the two basic units, the meter and the kilogram (and the scaling prefixes) are that old, the system is much newer. The MKS system was introduced in 1889 and SI, the well thought out system was first introduced in 1948.
The metric system has been and will always be a work in progress, once we are constantly improving our knowledge, technology, precision and methods. So the whole history of the system accounts for its present success.
And even today could use some improvement. The Kelvin and the related Celsius divide freezing and boiling point of water by 100 degrees. Which may be convenient for something, but it results in a strange quantity for the temperature rise from putting a Joule of energy into a kilogram of water. 0.00263 degrees C. It would be far more useful to have the metric temperature unit be chosen such that 1 joule into a kg of water resulted in one degree rise. Call that unit a Degm and it would equal 380 degrees C. Not necessarily a convenient size for deciding whether to wear a jacket or not, but the scaling prefixes come to the rescue here. Daily usage would be in milliDegm. Normal room temperature would be about 780 mDegm. A day when you would start to think about ice skating would be 718 mDegm. And for those in desert climates those scorching hot days would be about 850 mDegm.
Why isn't the whole world attacking such a logical improvement?
Temperature units are maintained in the SI because of tradition, but they are unnecessary, since we know that temperature is related to thermal energy, and we already have a unit for that, the Joule.
However, in the metric system this relation is governed by the Boltzmann constant, which is universal. So 1 K = 1.380 649×10⁻²³ K/J · 1 J. Add 273,15 and you have the ubiquitous degree Celsius. As simple as that.
And that gives you the right to be patronizing and sanctimonious, rude, and ignore actual facts given to you?
Solving this problem is simple. Switch to metric and get your sense of humor back.
And why in EVERY country, there remain things that are NOT metric!!! (It's infuriating how the metric advocates conveniently ignore this truth.)
You still don't get it. No one is ignoring the fact that there are a few things non metric out there. What we are rejecting is the use of this fact to justify the imposition, or at least the maintenance, of customary units.
**yawn**
What can I do? Now it's you that are ignoring a fact. So don't complain when you realize that the resistance of the people in the US to metrication is a world-wide object of derision.
Oh, please, do try and lecture me about the Amish.
And, of course, now that you are an expert in the Amish, my argument is invalid.
Um, no, everywhere that it matters they HAVE ALREADY switched.
The US is metricated where metric makes sense, and imperial where imperial doesn't.
