v6kgzo:
It is a shame that the USA didn't manage to export their rationalised ton & gallon to the world, prior to Metric appearing.
Imagine how easy it would be to convert if there were 2 lbs to a kg, & 2000lbs to a ton/tonne, but, alas, that was not to be, & that part of Metric grew from the already established traditional ton, gallons, etc.
If we had the internet back then, it would have been so much easier!
Hmm... so... I just figured something. A stone is 14 lb. 14 lb x 160 = 2240 lb. So... what's the Brit obsession with the stone?
OTOH, could Frenchy have made metric to fit better with imperial? There's not much good reason I can fathom why the meter has to be based on the circumference of the earth. Maybe it had to be completely different and appropriately sciencey in order to be accepted, but if Frenchy had wanted to, could he have made things more compatible?
But as it is, the only extra number I really seem to need in order to live with two systems is 2.54. So I think things worked out pretty good.
bsfeechannel:
No sir, a good engineer would also analyze why and how all others switched to a different solution than what is already in place and would study how to repeat the same successful experience.
You are not doing this. The "why" other countries did this is not nearly the same situation that modern America is in. Because of modern education and the internet. Also because of the size of our road system. Also, because of the manufacturing and machining history of America, upon which we relied on our own standard (we did not accept Brit standards made in 1825, because we had already gained our independence). We needed tools to build tools to make stuff. And we made them to our own internal standard, requiring and utilizing ever increasing degrees of precision and standardization. We did it in inches. We didn't care if they were compatible with the rest of the world, cuz we were on the other side of an ocean, and we were making stuff that didn't exist, yet. You just got your stuff from Britain and other EU countries. We were not part of that club.
Many of the former british colonies did not have much cost to changing, other than road signs and measuring cups. They were only changing a method of measuring the mud to build their homes and to measure the cuts to make their horse drawn carriages. Their economies were based on export of raw materials and import of things that were made with fancy tooling. More advanced nations sold tractors and logging equipment and mining equipment to these countries, so they could produce even more raw materials for export. All their imported pipes and doors and screws and wallpapers and brackets and veneers and tools were all being made in metric sizes. Even their measuring equipment was imported. Once more than half the manufactured goods and tools in their country were metric, and this condition was only increasing, and when they were asked to measure their raw materials in kg's, what the hell, why not? Why would they not change? All they wanted was continued mutually beneficial relationships and fair pay for their output. And then there are the politics, which I'm sure had some part in nearly every single metrication story.
All of these changes as might affect other countries, America was able to make without actually changing too much of its internal usage. That's partly due to modern education level and internal manufacturing capability. And now the internet/connectivity. And partly due to size; no one needs to drive from Canada to Mexico or vice versa, on a day trip. We essentially don't need to change in the way that was beneficial in other countries in other times. We don't have the pressures, today, that many of those other countries faced, financially and politically and practically.
Conclusion, the imperial system is perfect for penny-pinching drivers, people without a degree in meteorology and frightened pilots.
Hmmmm.
99% of the world does not hold a degree meteorology. Of the 1% that studied meteorology and received their degree, let's say 90% drive. And of those, let's say half are thrifty. Then let's add the 4 meteorologist pilots who are frightened.
So your message is... for roughly 99.5% of the world's population, imperial is the perfect system?
What engineering practice?
bsfeechannel, earlier in the thread: "Is driving a car on a road not engineering?"
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
