What is the exact economic benefit of changing the units we measure our roads by from miles to km?
I'll invert the question. What exact economic benefit did all other countries in the world see in measuring their roads in km instead of miles? Did they think they'd save on tires or fuel with that change?
Sorry, it doesn't work that way. You're trying to convince us to spend unknown (but surely ridiculous) amounts of money to replace every sign that indicates a speed or a distance, on every road in the entire United States.
I bet you that when you change a speed limit, you don't replace the whole sign, but instead just stick a new number over the old one.
1974 is a long time ago, & from memory, I think that was done in Oz, but maybe reflective stickers weren't quite up to it then,----we might have just replaced the oldest signs first, then progressively completed the others over years.
In any case, stickers is how you would do it now.
Another clever trick was to change each 5 mile increment of mileposts to an 8km increment, & remove the numbers from those in between.
People realised after a while that they didn't need posts every mile (or km).
We had those funny 8km posts for many years after '74.
[ I don't need to justify NOT doing it, YOU need to convince me why we should. All the drivers here think in miles and feet. Speedometers are primarily marked in miles per hour. Odometers register miles, not km. In addition to replacing all the signage, do you suggest that everyone get their odometers replaced? Re-gearing them won't work as that will bugger up the speed indication. (Not that re-gearing them is really any more sensible)
Most people would do what we did in Australia----do a quick correction in their heads.
35 mph is fractionally less than 60kmh, 50mph is pretty much spot on 80kmh, 55mph is just a bit less than 90kmh, 60mph is just a fraction under 100kmh, & 65mph is just a fraction under 110kmh.
The nearest Metric speed to the existing Imperial ones was chosen in each case, so drivers of cars with "legacy" speedos would still be able to drive within the limits.
A few people bought new "stick on" labels to fit into their speedos, others bought gadgets to gear the whole thing up, but the latter weren't at all satisfactory, as the higher speeds were now all crushed up at the end of the scale.
As I said, above, most people didn't have to do anything, so they didn't.
Granted in many newer vehicles with electronic indicators it may just be a code change, but it's still a trip in for an otherwise unnecessary service, and there are more than 270 million cars in the US. Do you expect every driver to pay an additional $50+ dollars per vehicle to get this done, too?
As I pointed out, it was unnecesssary to modify speedos in 1974, so why is it so essential, now?
You can't tell me that American drivers are stupider than Australian ones!
In my opinion at least (and, from what I gather, the opinions of at least several others here in this thread), you have utterly failed to present a worthy reason. "Because everyone else is" is not a very convincing justification to spend unknown billions of dollars to change something THAT IS WORKING JUST FINE FOR US!!
It doesn't matter what the number system is, as long as everything matches. The distance could be miles, or kilometers, or furlongs or kilosmoots, it wouldn't matter. I'm not doing engineering with those figures.
So you drive a motorized vehicle along a road and you think you're not doing engineering.
Are you suggesting that drivers ARE doing engineering? If not, what do you even mean by this statement?
Well, whoever builds and maintains the road is.
So? What difference do the units used when the road is constructed make to the end user? I drove up to Canada a few years ago. I really didn't notice any difference in the roads, and my American vehicle had no issues whatsoever traveling on them. Millions of people around the world plug their appliances and radios and computers into receptacles in the walls of their houses, and use those items as a matter of routine. How many of them do you think have the foggiest notion of where the electricity comes from or how it gets to them? Lots of engineering there, but no one really needs to know it in order to utilize the product. Knowing the engineering involved in many things is completely unnecessary to USE said things. Roads are among those things that don't require engineering knowledge to drive upon.
When I build a road in the US, I can use the meter. But then I have to give the distances in miles and clearances in feet and inches because the drivers will not understand that they can use the same unit that was used to build the road.
Yeah, and? So what?
And here we have the heart of the problem. While the cost of replacing all of the non-metric street signs in America is trivial, the cost of replacing his brain dead, useless, totally antiquated US sourced products that he bought with beautiful metricated products, or the cost of moving back to some enlightened, forward thinking, economically advantaged part of the world is totally unreasonable.
Pardon me while I shed crocodile tears.
Maybe you think that, because the US still uses imperial units, they are automatically fashionable. But I can assure you they are not.
Nor is that what we think, as has been pointed out to you REPEATEDLY in this thread. Are you truly incapable of grasping this, or are you being intentionally obtuse in order to continue making your arguments?
Outside the US, imperial is seen as deprecated, old-school, obsolete and, in many cases, a nuisance.
Then, once again, feel free not to buy or use any of our 'deprecated, old-school, obsolete, nuisance' things. I think I can assure you that we will not shed many tears.
-Pat
