It seems to be a voltage follower, with close to unity gain, and approximately 50 ohm input impedance. The slight attenuation of the 10 ohm series resistor and 47 ohm shunt resistor at the non-inverting input is only partially compensated by the slight loss in the feedback network to the inverting input.
