Those are not caps but are RF chokes inline with the DC input. Looks like they used some strange potting compound. The coils are wound with a quite thick enamel coated wire so in case of overcurrent, the coils would be the last component to overheat. I would expect burned wires rather than the chokes. Measure their resistance with a multimeter. You should get close to 0 ohms.
Yeah... I looked at them a little closer and saw a small bit of red peeking through the brown chocolate.. probably a choke. They just didn't pass my initial 'what could be horribly wrong' check of unknown equipment. I'll check and confirm their resistance.
This is HP's advertisement picture for the scope.
Suppoesdly it can also survive repeated drops from 3 feet onto concrete. (try it at your own risk unless you have some spare CRTs)
Wow! I never saw that image, thanks for the link!
I don't think i'd trust it that far anymore...
* The pressure equalizer valve on the top was missing... stuck a bolt in it to cover it.
* Several rubber domes and seals on the face are cracked from age.
Plus a 37 year old scope holding 20k+ volts dunked into water doesn't sound like a great idea
EDIT: just noticed, no power cable on the front of the scope in that picture... must be using the optional internal battery (which I don't have)
The caps all look ok for the moment. Definitely needs some calibration love though.. seems a little short vertically and horizontally.
Finished changing some 70's era fuses over the weekend and cleaning switch contacts. Gently using denatured alcohol on the yellow painted case seems to be taking away most of the "military surplus funk" and grime. I'd definitely recommend picking one up if you spot em'. Seem pretty solid and should last quite a while longer. One issue though is the lack of stock replacement parts. The knobs have the 70's bad plastic in them causing several to crack to various degrees. Trying to source a location of replacement knobs now. (The delay knob plastic is broken off but functional)
