Author Topic: Which LED HD projector?  (Read 4362 times)
Offline hacklordsniperTopic starter
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« on: November 21, 2011, 12:17:35 pm »
Since Christmas is soon its time to buy a present for myself. I always wanted to buy a projector for watching movies in the lab and various other uses (especially now after my tv was crushed in last overhaul).
On eBay choice goes from 200 $ with resolution 640X480 and 1300 lumens (peak) and 600:1 contrast for 100 inch screen up to 500 $ for 1024*768, 2000 lumens, 1000:1 contrast for up to 200 inch screen. None of them uses a "real" HD resolution.
What worries me that all of them are NoName Chinese products and specs could be pretty false.
And reccomendation is welcome?
Oh, the joy of sending various electronics to silicon heaven
Offline Psi
Re: Which LED HD projector?
« Reply #1 on: November 21, 2011, 01:21:00 pm »
Do you actually want it to be LED based or did you mean to say LCD?
Personally i wouldnt considering anything less than 1024x768
« Last Edit: November 21, 2011, 01:22:53 pm by Psi »
  • Country: hr
    • HackLordSniper
« Reply #2 on: November 21, 2011, 01:45:24 pm »
No i really meant LED based. The replacement lightbulbs are too expensive for my taste, and on average original bulbs cost 200 $ and up as replacement for 500 $ projector, since im going to use it quite alot i really want to go LED route.
Im considering Acer K330, its easily available locally, has 2 year warranty and specs seem quite good. Altrough its only 500 lumens of brightness it will be enough since i can easily darken room.
Offline SoftwareSamurai
« Reply #3 on: November 21, 2011, 09:05:01 pm »
Casio has some interesting non-bulb projectors.
Personally, I'm waiting for them to come out with a 1080p version before I give up my Epson 6500UB - even though it demands a new bulb every 4000 hours or so, or it explodes.  :o
Offline Psi
« Reply #4 on: November 21, 2011, 11:25:59 pm »
heh yeah, that one which people are buying just for the 24x 1W blue laser diodes. Then throwing the rest away.
  • Country: hr
    • HackLordSniper
« Reply #5 on: November 23, 2011, 01:36:59 pm »
Acer K330 is here, expect a tear down  :)
Offline rustyday
« Reply #6 on: December 03, 2011, 05:49:50 pm »
I have been searching for an LED Projector and found this for £399.
Technical Specifications:
Resolution: 1280 x 800 native, Full HD 1080p compatible
Brightness: 2,600 Lumens
Contrast Ratio: 3500:1
Aspect Ratio: 4:3 or 16:9 (note: older version projectors do not have 16:9)
Picture Size: 30" - 450"
Zooming: Digital and Manual
Fan Noise: Standard (average 20db to 30db)
http://www.projectorsite.co.uk/index.php?p=product&id=133&parent=26
A company called Abis based in the UK, it also mentions a 2 year warranty.
Anybody heard of these people?
« Reply #7 on: December 03, 2011, 08:57:58 pm »
Seems rather cheap inexpensive for such a "great" projector. But the proof is in the pudding, as they say. Someone should get one and...DO A TEARDOWN! ;D
(I'm still going to wait for a native 1080p version.)
  • Country: hr
    • HackLordSniper
« Reply #8 on: December 03, 2011, 09:00:14 pm »
Sounds nice. An acer K330 teardown is done, just to post it
Online Zero999
  • 0999
« Reply #9 on: December 04, 2011, 05:43:20 pm »
Watch the marketing BS. That projector is not full HD which is 1920x1080. It's just 1080 compatible which means any HD content will be scaled down to 1280x800.
