Author Topic: Good soldering flux?  (Read 53612 times)
Offline shapirus
  • Country: ua
Re: Good soldering flux?
« Reply #125 on: July 02, 2024, 07:14:53 pm »
Whatever gauge of the needle I use, within reason, or a conical syringe tip, it keeps blocking. I really hate that.
There are a couple of solutions for that : ) (I use the same stuff, 8341).
Solution 1: Use a metal tube nozzle, quite wide (I'm using 1.5 mm hole), and when it's near a hot air tool (i.e. just gently warmed) it will auto-unclog : )
Solution 2: When using a fine flexible plastic nozzle, I use a wire (e.g. through-hole resistor, or any bare wire), poke it around in the end a bit and then it egresses in a fine thin line (if that's what you want, ideal for small SMDs).
Photo shows the metal nozzle I use. Also shows a couple of other fluxes which I've not used yet, but hope to try out sometime.
Yeah. There are workarounds. Unclogging the hole with a piece of wire (solder wire!) is what I do. The thing is, I want to be able to just use the damn flux without any workarounds, and that's where it fails.
Offline forrestc
« Reply #126 on: July 03, 2024, 02:34:55 am »
You did not mention it cost more than gold
Only if you buy it direct from indium.
$37.50 for 30ml (big) syringe:
https://www.testequity.com/product/881SO202-FLUXOT-84283-30ml?gad_source=1&gclid=EAIaIQobChMIqvnno-mJhwMVwh6tBh1Yhgx_EAYYASABEgJVwvD_BwE
Or $27.12 after eevblog discount at tequipment:
https://www.tequipment.net/Indium/FLUXOT-84283-25-GRAM-SYR/Flux/
I usually use a coupler to transfer it into another (smaller) syringe and then keep the big tube in the fridge with the solder paste.
Still not dirt cheap, but not $150 either.
Plus, there are two formulations.   TACflux-020B and TACflux-020B-RC.   The RC is (for whatever reason) rated for a 6 month shelf life. and the non-rc is 12 months.
« Last Edit: July 03, 2024, 02:41:43 am by forrestc »
Offline Postal2
  • Country: ru
« Reply #127 on: July 03, 2024, 03:36:06 am »
I recommend:
Offline tooki
« Reply #128 on: July 03, 2024, 02:41:18 pm »
Thanks it makes sense. I will give it a try in my ultrasonic cleaner with IPA and heater on ... I need to buy a gallon of 99% IPA somewhere... (fun fact if you google "IPA gallon" only beer shows up).
Do not do this!!
It’s not safe to fill a regular ultrasonic cleaner with flammable solvent. And it’s expensive.
Instead, fill the machine with water. Then place into the water a smaller container of solvent with the dirty item. The container can be open (like a tray or beaker) or a plastic bag. Plastic bags are a great way to massively reduce your solvent consumption, since you can put in your board and then just enough solvent that when zipped closed, the board is submerged. Seal a bit of air into the bag; this will keep the open end of the bag floating at the surface.
The following users thanked this post: PlainName, Zucca
Offline Smokey
  • Not An Expert
« Reply #129 on: July 05, 2024, 12:50:47 am »
Ethanol eh?  How about $20 per gallon?
https://www.totalwine.com/p/1825175-1
Two for the boards..... one for me...
