Anybody know the correct name or a manufacturer of those plastic split cable clamps that fit in an oval hole. There in 2 pieces with a thin strap holding the 2 parts together,you put them around the cable. push the 2 parts together,then push the assemble into the hole and rotate the whole thing 90 degrees.
