If it was used in food processing it likely will be a Nylon 6.6 or HDPE, as these are food safe. PTFE will be soft and slippery. I have some PTFE stock I use to turn out bushings for food grade equipment, and some Vesconite that is used for the inner bushes away from the product. Nice thing about the Vesconite is it is both self lubricating and water lubricable, though you find the shaft wear is a lot more. PTFE is just soft unless glass filled, when it turns into a pretty good grinding media.
This stuff is very slippery. I made a tiny conical knob out of it that fits on the tiny pots with the 1/8" shafts and it's too slippery to use. It's nice on big pots though.
I can push a chunk of it against a table sander and it doesn't melt at all. Regular plastic just turns to goo if I do that.
Do you now if Nylon 6,6 is THAT tolerant to heat?
From what I can find... "Type 6,6 nylon melts at 255-265°C" but I have no clue what temperatures are created when sanding plastic.
It's a thick chunk of scrap and I doubt it's anything expensive. PTFE is probably a bit pricey to use in large quantities.
This is becoming quite interesting, talking about plastic on the EEVBlog
