So something explosive has to be in active use as weaponry by terrorists and criminals before you consider it properly dangerous?
Either that OR it causes significant damage to other people.
If a guy very rarely blows up his van or his shed or his entire house, it's unfortunate.
Just google suicide rate and compare that to how many people die from acetylene accidents and tell me why it matters.
And you think spending tax payer money for a bunch of cunts to come up with a formal accreditation course will fix that? You think the guy in the van knew his tank was leaking but didn't know it could explode? No, it was an accident, and he didn't know the valve got bumped.
It takes a paragraph to describe what not to do. IanM pretty much covered it. I wonder what else they can do in a licensing class that will mean squat other than bore people to death.
And tell me, what percent of applicants do you suppose are going to fail this course/test? If you said anything but zero, you're kidding yourself. Accidents happen in real life; it's not because people are too dumb to pick the right answer on a common sense multiple choice quiz while someone is watching.
It's like you think needing a license to buy rope, or some education about how people squish when they fall from 100 feet, is going to stop people from falling off mountains.
When the guy in the van's family successfully sues the distributor of the acetylene... this is when you will need a frigging license and registration to buy acetylene. It will be to protect the seller, not you.
