Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2374555 times)
Offline tooki
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #4775 on: September 24, 2023, 01:04:15 pm »
Pardon my ignorance but is there a special cabinet where you store all the famous Swiss chocolate? :popcorn:
Special cabinet? This is Switzerland, there’s an entire room just for chocolate! :p
The following users thanked this post: SeanB, edavid, Warhawk, Howardlong, Edison
Offline pac1085
« Reply #4776 on: September 24, 2023, 11:16:13 pm »
I added some shelving to the left of my test bench and some new test equipment since my post earlier this year.  The other benches remain the same, more or less.
1883461-0
The following users thanked this post: Smokey, edavid, exor, salvagedcircuitry, Edison, audiotubes, Atomillo
Offline Edison
  • Country: cz
« Reply #4777 on: October 10, 2023, 08:57:28 am »
Hello, you have a great workplace,  :-+    so now I envy you two things to the Panasonic audio analyzer, a Tek curve tracker has been added  |O Actually three, the third is a space for work  ......... ;)
Nice day  :)   Tom
« Last Edit: October 10, 2023, 09:04:13 am by Edison »
Everything works as the weakest link in the chain
Offline Edison
  • Country: cz
« Reply #4778 on: October 10, 2023, 09:01:55 am »
Switzerland is far, it doesn't bother me, but I want that room   :-DD
Nice day  :) Tom
Offline RoGeorge
« Reply #4779 on: October 10, 2023, 11:47:00 am »
Since it's Switzerland, chances are such rooms might be as well an entire underground bunker of chocolate!  Suspecting to be so because of this:  Switzerland Has 374,142 Bunkers (and likely more):D
The following users thanked this post: tooki, Mortymore
Offline Edison
  • Country: cz
« Reply #4780 on: October 10, 2023, 01:27:31 pm »
Amazing video, but I didn't see purple cows anywhere, only normal ones, they are probably in special Milka bunkers somewhere  :-DD
Offline themadhippy
« Reply #4781 on: October 12, 2023, 05:53:02 pm »
Also no sign of triangular almonds from triangular trees nor any triangular honey from triangular bees.
Offline coppice
« Reply #4782 on: October 12, 2023, 07:22:06 pm »
and oh Mr Confectioner please, give me LSD.... I mean.....
Offline tooki
« Reply #4783 on: October 14, 2023, 12:34:06 pm »
Nah, no purple cows — the Milka brand was originally Swiss, but for practically the entirety of the brand's existence, it's been manufactured in Germany. I'd say it's a de-facto German chocolate brand, and you don't see here that much.
As a consolation, I've attached a purple polar bear, which is cute as heck. (No, it wasn't a marketing gag. It was gentian violet, used to treat a skin condition.)
Offline tooki
« Reply #4784 on: October 14, 2023, 12:34:49 pm »
Another Swiss invention!  ;D
Offline tooki
« Reply #4785 on: October 14, 2023, 12:50:56 pm »
Indeed. But have you heard of long eggs? They've all but vanished in Switzerland these days, with even ready-to-go supermarket salads using sliced real eggs, but back in the 80s and 90s they were a staple of restaurant salads, canapes, etc. I recall them as being entirely bland and looking a bit like like foam rubber due to the air inclusions. (I have a suspicion, albeit without evidence, that the yolk part was actually diluted with a lot of egg white to make it easier to slice.)
Here's a lovely German kids video about how those abominations are made:
Offline Smokey
  • Not An Expert
« Reply #4786 on: October 14, 2023, 08:03:15 pm »
"Skin Condition".... Suuuuure....
We all know what's going on there... That is one Woke-AF, Gen-Z polar bear!
Offline themadhippy
« Reply #4787 on: October 14, 2023, 08:10:49 pm »
yep,an essential ingredient in gala pie
Offline RoGeorge
« Reply #4788 on: October 14, 2023, 08:20:01 pm »
The purple bear could be as well the offspring of an interracial between a Milka purple cow and a Polar bear.  :-//
Offline McBryce
« Reply #4789 on: October 15, 2023, 09:56:57 am »
Or maybe someone didn't sort the laundry properly and put a bear and a cow in the same wash?
McBryce.
The following users thanked this post: tooki, RoGeorge
Offline tooki
« Reply #4790 on: October 15, 2023, 11:31:47 am »
Surely those pies can be made with conventional hard-boiled eggs?!?
Offline tooki
« Reply #4791 on: October 15, 2023, 11:32:28 am »
Please don’t. Totally unnecessary and not funny.
Offline themadhippy
« Reply #4792 on: October 15, 2023, 01:13:39 pm »
on a small scale i guess they might,but at least one of the uks larger manufacturers made there own version of the long egg. Admittedly its been sevral years since i was  in there factory so thing may of changed.
« Last Edit: October 15, 2023, 01:15:23 pm by themadhippy »
Offline PlainName
  • Country: va
« Reply #4793 on: October 15, 2023, 03:36:23 pm »
Small ones, but whatever the size you get the issue that some slices will have no egg, or just white, while other slices get the full thing. BTDT. Our solution was flat egg, rather than long, since it was a round gala pie.
Offline Edison
  • Country: cz
« Reply #4794 on: October 25, 2023, 09:10:25 am »
So back to the topic, I have improved the options for testing audio components a bit. After making a 300W 1x2, 1x16 Ohm or 2x4, 2x8 Ohm) dummy load myself, installing a Tektronix 2465 oscilloscope, I replaced the test amplifier with a Yamaha DVD receiver and made a new patch panel. Small speakers on the sides of the connection panel will allow you to listen to the signal in artificial load mode. A rotary switch allows you to connect a test VU meter to the appropriate inputs or outputs.
« Last Edit: October 25, 2023, 10:49:40 am by Edison »
Offline Edison
  • Country: cz
« Reply #4795 on: October 26, 2023, 06:38:00 am »
For the Yamaha receiver, I modified the power supply a little and completed a galvanically isolated five-volt branch for the stereophonic BT module 5.0, which is automatically activated when the amplifier is switched on.
I custom-made all connecting signal cables and they are connected as directional to minimize interference of the tested signal
« Last Edit: October 26, 2023, 06:50:12 am by Edison »
Offline audiotubes
  • Country: cz
« Reply #4796 on: November 21, 2023, 02:12:13 pm »
Just arrived today:
I have taken apart more gear than many people. But I have put less gear back together than most people. So there is still room for improvement.
Offline Warhawk
    • Personal resume
The following users thanked this post: audiotubes
Offline rdl
« Reply #4798 on: November 22, 2023, 11:45:11 am »
Pretty nice. I like pegboard.
The following users thanked this post: Ed.Kloonk, audiotubes
Offline Edison
  • Country: cz
