Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2362363 times)
Online richnormand
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #4600 on: October 04, 2022, 07:38:24 pm »
@voltage
Like your powerbar. Can you share more info?
Cheers.
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline RAPo
« Reply #4601 on: October 05, 2022, 02:48:41 pm »
Small (depth 70cm length 170 cm) but usable. (note to self if you get more scopes you need another bench;-))
Offline PlainName
  • Country: va
« Reply #4602 on: October 05, 2022, 03:40:37 pm »
Why do you need more than one (or two) scope(s) on the bench? I can appreciate having many, but surely you use or need available just one (or two). The ones high up aren't really usable and take up space other kit could be using.
Offline RAPo
« Reply #4603 on: October 05, 2022, 03:46:59 pm »
Indeed I need two scopes (Tek 2225 and Rigol MSO5104) and they are within direct reach.
However, I like old analogue scopes and need a place to store them.
The following users thanked this post: PlainName
Offline Edison
  • Country: cz
« Reply #4604 on: October 09, 2022, 07:41:31 pm »
Well, if you need to save them, I'll send you the address ;D
Everything works as the weakest link in the chain
The following users thanked this post: RAPo
Offline deadlylover
« Reply #4605 on: October 14, 2022, 08:37:57 am »
I did some prototype art bench lighting. The funny cardboard "luminaire" is so I cannot see the emitters directly and have no bright spots on my vision. There's some reflective film inside I think I originally planned this to mount above a monitor for desk lighting like those fancy BenQ screenbars.
LED strip used is from Cutter (SSK-1560ZGE-50299NIC), LEDs are the Nichia 757 optisolis series. CCT ~4600K Duv =-0.0016, CRI Ra = 99, R9 = 94. TM-30-15 Rf= 98, Rg = 100. It might as well be museum class lighting ahahah.
Powered with a 25W Meanwell LED driver that is adjusted with a Bourns 3500S 10 turn wirewound pot (it was on special lol). I have another strip powered from it that does general room/PC desk lighting so it only sees say 12W on full chooch.
I need to heatsink it with some square aluminium tubing, there is a 40C rise over ambient @ 12W drive which is in spec (100C ambient, 120C junction) but makes me uncomfortable. That's about 650 lux on the desk though and at a more reasonable 150lux or there's a 13C rise if that.
A museum would only display sensitive work at say 50 lux, while the ASTM D1729 standard for a light booth used for visual appraisal of colours calls for 810-1880lux. Maybe that's a bit too nuts for casual late night doodling sessions ahahahah.
Offline Ground_Loop
« Reply #4606 on: October 15, 2022, 10:57:19 pm »
Never seen a bench with all the BNCs capped.
There's no point getting old if you don't have stories.
Offline RAPo
« Reply #4607 on: October 16, 2022, 08:19:55 am »
The photo was taken after an extensive reshuffle because the Enertec 5224 joined the club.
Before such a reshuffle I always cap all connectors.
Offline DL8RI
« Reply #4608 on: October 24, 2022, 08:05:55 pm »
I guess, I do fall into that category?! And sanity was never an option....
My special interest is (very) high frequency stuff, so things that go into the two or three digit GHz range. So black magic in general. :)
That again needs a lot of general support electronics and a lot of TE that has to be repaired. And the latter opens Pondora's box on what stuff you will need (spiler: everything!).
Edit:
Sorry for the rotated images. Neither my phone, nor my pc, nor Instagram has an issue with that, only this forum here.
Is that a B&K 2425 AC voltmeter I see on the shelf there? I have a one of those been in my repair queue since 1999. It's finally in bits on the bench: the negative power supply is u/s, but I need to trace the circuit out to progress further. B&K notoriously never provide circuit diagrams
Nope it is a 2609. The others are 2636 of which I happened to own one already and then find 3 or 4 units in the trash. Well, now I have plenty (until I finally manage to give them away).
Sorry for the "timely" response, I am somewhat occupied renovating my new house (with a new Lab... more than 20 m² :) ) and did not log in here ever since posting...
Offline PixieDust
« Reply #4609 on: November 11, 2022, 03:39:58 am »
After going through the whole thread from start to finish, what I have learned is that you want shelving. All the really nice setups go vertical.
Offline _Wim_
« Reply #4610 on: November 11, 2022, 06:07:53 am »
That and a deep bench, so you still have plenty of space in front of the shelves to have a decent working area (but not too deep so you cannot easily reach the equipment on the shelves...). Shelves also need to be deep if you are into vintage HP gear.
As an example what works for me, I use a 1m deep bench, with 55cm deep shelves. The equipment that is directly on the bench does not occupy the full 55cm, but maybe max 45cm, so this leaves a working area > 0.5m.
Offline PixieDust
« Reply #4611 on: November 11, 2022, 07:48:08 am »
Agreed. I spent my whole life behind a single small desk. I never had enough space. A few years ago I purchased a 900mm deep desk and it has absolutely changed my life. In fact, it's only a tiny bit too crampt. I wish I had another 10cm, then everything would fit perfectly when I'm doing stuff.
Offline PixieDust
« Reply #4612 on: November 11, 2022, 08:23:57 am »
Here's mine.
All the leads for the oscilloscope and DMM, the ESD mat, the soldering iron and projects are tucked away in the drawers.
« Last Edit: November 11, 2022, 12:50:51 pm by PixieDust »
Offline _Wim_
« Reply #4613 on: November 11, 2022, 09:06:36 am »
Here is mine in its current messy state...
Offline Psi
« Reply #4614 on: November 11, 2022, 11:04:33 am »
Yours in a messy state looks like what mine looks like when in a tidy state
Offline _Wim_
« Reply #4615 on: November 11, 2022, 06:42:09 pm »
I have to admit, it can be worse also  ::)
Online richnormand
« Reply #4616 on: November 11, 2022, 08:19:59 pm »
"Here is mine in its current messy state..."
Care to elaborate about the optics on the left bench?
Cheers
Offline _Wim_
« Reply #4617 on: November 11, 2022, 08:41:33 pm »
Cheers
On the left:
These are parts of an older ellipsometer I found on Ebay. I want to use these as an automatic polarization analyzer. I have a bunch of unlabelled mica quarter waveplates, and would like to closely characterize them to build a few optical isolators and of course also use them as quarter and half waveplates.
Currently I have realigned the optics in both polarizer and analyzer (I get a 1/30.000 attenuation when analyzer and polarizer are at 90°), and have reverse engineered the old encoder and motor windings of the analyzer part.  Currently I am working on writing some firmware for a STM32 board to control the motor and read in an optical power meter via and ADC1256. Analysis will be done on the pc (still need to delf into Jones calculus to make this all work, so will not be finished soon)
On the right:
This is a laser marker system in progress. It will consist of a jenoptik smaragd laser firing into a beam expander that enters a scanlab galvo. Galvo and laser will be controlled by an LMCV4 controller. Also work in progress, currently the LMCV4 is damaged due to a grounding error by me, but I should be able to fix it (parts on order)
Online richnormand
« Reply #4618 on: November 11, 2022, 11:33:27 pm »
Very nice. you might consider posting something in "projects" eventually!
My background is in nonlinear optics so I was intrigued.
Thanks.
Offline _Wim_
« Reply #4619 on: November 12, 2022, 06:55:04 am »
Thanks.
Good idea & good to know some optic experts are also "hiding" in this forum  :). That could be useful for an optics hobbyist like me. My problem is mostly working on too many projects simultaneously and shifting focus quite often between them. For example I am currently also working on reverse engineering an FTNIR (Buhler/Buschi NIRFlex N-400) in the hope to use my own software/electronics with it. Motor movement is ok (was easy, were 2 stepper motors) and I have traced back where I can record the laser reference signal and the interferrogram (see recording with my picoscope). So digitizing those should be sufficient I think to recreate the NIR spectra...
Goal is here to use similar electronics hardware as for the polarization analyzer (stm32 board with ADC1256 and motor controllers), and do the rest on pc (C# application). But also here, progress is not too fast, hence sometimes a "fear" of posting because I will not be able to provide regular updates...
The following users thanked this post: richnormand
Online Anthocyanina
  • The Sara
« Reply #4620 on: November 24, 2022, 06:34:47 pm »
I finally organized my desk/bench!
yes, my pc is a wooden plank!
The following users thanked this post: Ed.Kloonk
Offline SiliconWizard
« Reply #4621 on: November 24, 2022, 10:21:23 pm »
Only 3 screens? ::)
Offline tautech
« Reply #4622 on: November 24, 2022, 10:30:17 pm »
Only 3 screens? ::)
Gotta fill all the holes on the back of the Mobo.  :P
Online Anthocyanina
  • The Sara
« Reply #4623 on: November 25, 2022, 08:56:51 am »
Only 3 screens? ::)
what else can one do!  :P
Online Ed.Kloonk
  • Cat video aficionado
« Reply #4624 on: November 26, 2022, 06:21:04 am »
As someone who runs PCs in cases that have never had the side cover on, I find that presentation so salacious, I'm wondering if it should be illegal.
iratus parum formica
The following users thanked this post: Anthocyanina
