This is my small home workshop which is in the loft of our terrace home which i use with my brother on electronics and other projects.
The loft space is 4.1m long, 3.2m wide at its widest point and 2m high in the middle.
![](http://briandorey.com/docs/loftworkshop/header.jpg)
At one end of the room are storage trays covering the wall with hundreds of trays of resistors, capacitors, semiconductors, leds, fixing hardware and lots of other small parts.
Each side of the loft space has shelves which have more storage under each one with storage trays and boxes full of everything from computer parts to camping equipment.
One side has our Pick and Place machine with drill and milling bit drawer under the shelf and the other side has an N gauge model of the Swanage steam railway with a protective lid over to keep the dusk out and lots of odds and ends currently stored on top!
At the far end of the workshop is the main work bench which has small hand tools across the back wall on storage clips, a central work area with Metcal soldering irons and fume extraction system. The left side has all our main test equipment including a 60MHz 2Ch Oscilloscope, function generators, frequency counters, various multimeters and variable power supply. There is also a Shuttle PC which is used for development on PIC’s and Arduino.
Under this bench is our SMD oven in a sealed box with air vent which extracts the fumes outside and also a OKI air filter to use when soldering on the bench. Either side are more storage boxes with old projects and bits of wire and connectors.
Above this shelf is another storage shelf which has a hot air SMT rework station, rolls of tape, solder and heat shrink in different sizes.
Next to the access trap hatch / ladder is the CNC mill which is run using Mach 3 on an old Dell PC and small hobby lathe.
There is a 360 pano tour of the workshop on
http://apexviews.co.uk/loft/
