Detail of the panel, filtered power + USB hub and top shelf.
Can you explain more about the power bar you have?
No problem
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Upper PWR panel separate overvoltage protection and main switch for PC and peripherals pc.
Lower PWR panel is the equipment working table, these panels are two (right and left) on the control panel position with five switches - switch black color and LED - control measuring workplace (meter - orange jack), the second switch + LED - controls the white sockets on the sides of the measuring panel, dual USB and the lower PWR panels, the third switch controls the built-in vacuum cleaner and the other two workplace lighting (I can combine the chromaticity of the light 2700k 3500k 4500k 6000k - at 6000k it is nice to see the cold connections with the naked eye)
The middle white socket is only connected to the banana field, the presence of voltage is indicated by the LED in the right corner of the socket.
the other switching the 230V on the banana field is indicated by the LED, the green socket with the protector, the orange socket without a protector - both controls the right switch, the left switch is switching between the anti short-circuit proof circuit (LED lights green) and the hard power supply (LED lights red) for the measuring part of the panel.
Cinch modul - audio video in, jack 3,5mm audio modul switch in/PC for Cambridge Audio, Ethernet modul, PWR USB 2,5A modul, USB + GND modul - conect to PC for microscop and multimeter.
The meter in the panel provides for reading of voltage, current, power, calculates the cost of energy consumption and can set an alarm for exceeding the set current.
The measuring panel has separate protection and overvoltage protection, both panels ( central PWR and PC ) can be backed up by a large UPS (I am servicing - faulty batteries damaged the charging part).
If the problem or the end of the job is enough, turn off the switches and all is turned off, except for the red socket
