Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2389657 times)
Offline djos
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #2875 on: October 01, 2017, 08:02:02 am »
I got sick of dragging my laptop out to the workshop, so I dug up my old Pi v1, slapped the latest version of Raspian on it, added some heat-sinks, cranked it up to 1Ghz and mounted it behind my workshop LCD Screen. Works great for viewing project docs and schematics while building and repairing stuff.  8)
Offline bitseeker
« Reply #2876 on: October 02, 2017, 12:51:09 am »
blueskull, I like your mess. Lots of nice goodies on the bench. The wall mount for your laptop is particularly nifty.
Offline cdev
« Reply #2877 on: October 02, 2017, 12:52:41 am »
Blueskull. Be careful with your macbook!
Also, I am surprised that you can run both monitors off of one cable..that does look good for decluttering, so this must be new, are they daisy chained using Thunderbolt or something?
Offline bitseeker
« Reply #2878 on: October 02, 2017, 06:57:46 am »
Thanks for the clip info. :-+
Offline Jelcke
« Reply #2879 on: October 02, 2017, 04:59:59 pm »
Finished my bench yesterday and it is already chaos. Busy testing a FE-5680A Rubidium Reference standard. Thanks for all the previous posts. Great inspiration.
Any suggestions on improvements are welcome. (ESD mat is on the way..)
Offline guido
« Reply #2880 on: October 02, 2017, 05:15:55 pm »
Do not run that rubidium without a proper heatsink!
Offline Jelcke
« Reply #2881 on: October 02, 2017, 05:46:22 pm »
yes, that is a good suggestion. It is not getting too hot at the moment but I would not enclose it without a heat sink.
Offline AF6LJ
« Reply #2882 on: October 02, 2017, 07:20:02 pm »
Keep the Bench Porn coming.  :-+ :-+
Sue AF6LJ
Offline nanofrog
« Reply #2883 on: October 02, 2017, 09:09:03 pm »
A monitor arm would free up some shelf space, and maybe add another shelf as you've already maxed out what you have.  ;D
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #2884 on: October 02, 2017, 10:12:20 pm »
I don't know about calling it 'porn', but mine is certainly a dirty hot mess right now!!
-Pat
Offline NiHaoMike
    • Facebook Page
« Reply #2885 on: October 02, 2017, 11:28:51 pm »
Testing my new HVP70 isolated probe. Had to wire up a frequency dependent attenuator since the data packets are tiny compared to the mains voltage. It still kinda boggles the mind that it's possible to stream HDTV over the power lines.
Offline Mr. Scram
  • Display aficionado
« Reply #2886 on: October 02, 2017, 11:51:45 pm »
-Pat
I like the box marked "fragile" tossed casually upon the pile.
Offline alpher
« Reply #2887 on: October 03, 2017, 12:00:22 am »
Project Rainbow in its glory. :palm:
« Last Edit: March 27, 2018, 03:36:18 pm by alpher »
Offline Cubdriver
  • Nixie addict
« Reply #2888 on: October 03, 2017, 12:52:41 am »
 :-DD  It was placed there so it would be far enough in not to be knocked over by any of the furballs, though that probably wasn't necessary.  It contains (4) 6021W subminiature tubes from the 'bay, and is what they shipped in.  The seller packaged  them very well, wrapping them in pairs in small bubble wrap, then putting the pairs in a small octal tube box, then putting that in the aforementioned box, immobilized therein with peanuts.  I could probably throw them against the wall with all my might and they'd be fine.
-Pat
Offline Cubdriver
  • Nixie addict
« Reply #2889 on: October 03, 2017, 01:53:58 am »
What are you doing with them? Portable audio amp?
Just a word of suggestion, that these may be microphonic if you carry them around.
I've made portable amps out of 6N16B, and they are very microphonic.
I'm thinking just a really tiny tube amp; something that would still be line powered and sit on a shelf.
-Pat
Offline neo
  • The specialist.
« Reply #2890 on: October 03, 2017, 02:13:07 am »
I have found one truth to be self evident in my hobby of studying history, anything is possible and that which is not yet seen as possible is merely not properly understood.
The following users thanked this post: NiHaoMike
Offline ChrisLX200
« Reply #2891 on: October 03, 2017, 09:53:45 am »
I had to work hard to find room for an electronics workbench in my workshop! As you can see, I decided to convert the work area shown in the first photo, then packed my gear around there. Today I have to find yet more room for a desoldering station :-) The rest of the workshop is full of machine tools so further expansion possibilities are 'limited'.
ChrisH
Offline Rémi
« Reply #2892 on: October 03, 2017, 10:45:27 am »
ChrisH
The fan on your bench is a solder fume extractor? With a on/off switch and potentiometer for the speed?
I want to build something similar for my bench that's why it caught my attention  ^-^
Offline ChrisLX200
« Reply #2893 on: October 03, 2017, 10:58:49 am »
ChrisH
Yes, and I'm just awaiting delivery of some of these filter pads ( http://www.ebay.co.uk/itm/10-20Pcs-5-x5-Square-Universal-Activated-Carbon-Air-Filter-Sponge-Foam-Pad-Set/322612785845?ssPageName=STRK%3AMEBIDX%3AIT&var=511608281536&_trksid=p2060353.m2749.l2649 ) then I'll make a case with a couple of those in front and behind the fan. Should make it more effective.
ChrisH
The following users thanked this post: Rémi
Offline AF6LJ
« Reply #2894 on: October 03, 2017, 11:48:26 am »
Nice shop Chris. :)
Sue AF6LJ
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2895 on: October 03, 2017, 11:57:58 am »
Offline Sparks
« Reply #2896 on: October 03, 2017, 01:55:16 pm »
Excellent shop Chris
Offline Cubdriver
  • Nixie addict
« Reply #2897 on: October 03, 2017, 02:16:44 pm »
Mmmmm...  Vertical milling machine.  Want!!   ;D
Nice setup you have there, but yes, you certainly don't seem to have much space to spare!
-Pat
Offline ChrisLX200
« Reply #2898 on: October 03, 2017, 02:42:53 pm »
The desoldering machine arrived today as promised and I managed to squeeze it into a corner of the bench :-) Anything else I buy then something will have to go - I may need to sacrifice the stereo music system under the bench top... LOL. It was my daughter's and she grew out of it - seems she has an iPhone permanently grafted to her head instead (and I didn't want to just throw it out).
My stereo microscope is very old, but was made by Zeiss and is optically superb. It came with a bunch of accessories like additional viewing ports (for camera and second eyepieces so someone can see what you're doing). Got it for nothing so can't complain :-)
Offline sarel.wagner
  • Cooking up an Electronix Storm
« Reply #2899 on: October 03, 2017, 04:28:37 pm »
Chris nice indeed, got a lot of similar tools, also Myford Lathe, just older, chinesium Mill, but my shop is split across different rooms/areas. Electronics lab in one, reloading and guns in another adjacent room. Lather in yet another one and mill in another area. Still need to move the mill to same place as the lathe and Mig/Tig area. The electronics area was only build earlier this year.
