My hardware workbench
![](http://www.siliconvalleygarage.com/circuitsonline/2012/fehok1.jpg)
left to right :
- Agilent 16702B logic analyser with two 16750a analyzer blades (400MHz state / 2GHz timing / 4Meg memory per channel , 68 channels ) , one 16520 pattern generator (32 channels , 200 M vectors / second) blade
- Agilent 54832D 1GHz 4Gs/s 4+16 channel oscilloscope. Deep memory option (128 megasamples per channel)
- Agilent E3610 analog power supplies
- Agilent 34401 6 1/2 digit Digital multimeters
- Agilent MSO7104A 4+16 channel 1Ghz 4Gs/s oscilloscope. Deep memory option / packet decoders . this is my main machine. The reason i keep the 54832D is because i have the FPGA licences for that one. it allows me to debug inside FPGA's and that scope is timesynced with the logic analyzer so i can do mixed signal stuff
- Agilent 33120 arbitray generator
- Agilent E2641 3 channel power supply
- Agilent 8904A synthesizer. This thing has differential isolated output. ideal for precise LF applications
- Agilent 5334B counter with Oven option
- Agilent 8116 function generators. One with option 001 ( burst and modulation modes)
- Agilent 3225B signal generator. this one can do up to 40 volts p/p .
- vision engineering mantis with x8 super long working distance lens and x4 lens ( i primarily do SMD stuff... 0402 0603 , sometimes smaller )
All the generators are locked to the crystal oven in the counter.
My battery of soldering irons. smd tweezers, hot air pencil , microtouch for very precise work, two wsp80 with different tips ( so i don't have to swap all the time ) and a desoldering gun
My software workbench
![](http://www.siliconvalleygarage.com/circuitsonline/2012/fehok2.JPG)
- General purpose power supply / counter / fg/ dmm
- Agilent 54831A 600Mhz 4Gs/s 4 meg deep memory general purpose scope
- older 54645D 2+16 scope 100 Mhz. primarily used for the digital channels
Not shown : my pile of half repaired / half broken / stuff to be scrapped / sold / donated equipment. a bunch of 16500A and B / 16700Alogic analysers with blades , A lecroy wavemaster scope ( bwuaaark. should be called lecrap )
Most of my equipment was gotten cheap/free because it was broken. Over the years i've gotten pretty good at repairing agilent equipment.
I traded a bunch of other scopes (tektronix TDS7xx / agilent 54645D's ) for the 54832D and the MSO7104. The Logic analyser was bought from a company that stopped hardware development 4 year ago. They only sell software now ( they used to have an asic running their software, now they license the algorithm.. ) They were moving and nobody still there knew what this machine was. It was on ebay for 300$ ... local pickup only.. and i got it! This was more than 120K$ machine when new 8 years ago ...
