Pack the probe in the original shipping containers. Original materials areavailable through any Agilent office. Or, use the following guidelines:• Wrap the probe in antistatic plastic to reduce the possibility of damagecaused by electrostatic discharge.• For probes weighing less than 54 kg (120 lb), use a double-walled, corrugatedcardboard carton of 159 kg (350 lb) test strength.• The carton must be large enough to allow approximately 7 cm (3 inches) onall sides of the probe for packing material, and strong enough to accommodatethe weight of the probe.• Surround the equipment with approximately 7 cm (3 inches) of packing material,to protect the probe and prevent it from moving in the carton. If packingfoam is not available, the best alternative is S.D-240 Air Cap™ fromSealed Air Corporation (Commerce, California 90001). Air Cap looks like aplastic sheet filled with air bubbles. Use the pink (antistatic) Air Cap™ toreduce static electricity. Wrapping the probe several times in this materialwill protect the probe and prevent it from moving in the carton.
What would you even use those for? Directly probing a 1MW generator or something?
