Does tough love count ?
Made in Dex by the Author of Dex ...
The 'Typical Horn Circuit"
- Ford Horn Ciruit (cir-uit typo -1-)
- for a ..dodge viper (car image -2-)
- with three horns (yeah sure, typical cars have three horns. -3-)
- with a shorted relay coil (that relay never does anything -4-)
- and missing connection dots (at least 5 of em -5,6,7,8 and 9 -)
- and a switch that does nothing but connect the horns, through a resistor and a mystery box labeled 'y', to ground. -10-
- on a sheet labeled 'Horn Ciruit' (Cir-uit typo -11-)
Designed by someone appropriately named Art, initials S.M. . At least Art is happy with Dex: it fits his S.M. tendencies to a dot.
So there is at least one known customer that uses it...
And all this at revision 1:8 .
At this rate we're going to need 64 bit integers for revision numbers , before we get this one error-free.
Maybe we should use floating point numbers as DEX is really good with em. The zero: zero coordinate can be represented in at least three incorrect ways. All close to, but not quite, zero.
Love and kisses.
