Author Topic: What's this please? (Component Advice)  (Read 1267968 times)
Offline w.v.s.
Re: What's this please? (Component Advice)
« Reply #1875 on: March 27, 2024, 10:48:47 pm »
And here is the older version. Same question and one additional one: I guess HRS does not stand for "hotel reservation service" in this case. I wondered, if it could mean the connector was fabricated by hirose, since these are the consonants in the name it is also a Japanese company.
« Last Edit: March 27, 2024, 11:10:18 pm by w.v.s. »
Online helius
« Reply #1876 on: March 28, 2024, 01:41:05 am »
Yes, that is Hirose's logo.
The first plug may be by Binder, I will look in some catalogs.
« Last Edit: March 28, 2024, 01:43:16 am by helius »
The following users thanked this post: w.v.s.
Offline squibby
Re: Strange tube thingy
« Reply #1877 on: March 28, 2024, 04:19:56 am »
What might this be?
Relay in a vacuum so that there is no arc when it breaks or makes. Minimises noise when switching an amp on or off for example. Could be timed, could simply be instantaneous. The vacuum is the key feature.
Offline Zeyneb
« Reply #1878 on: May 09, 2024, 01:21:00 pm »
Hi there,
It would be nice if someone can give a suggestion for that plug on the right.
I'm going to redesign that PCB on the left so I do not need an exact match for that plug. The function is a trigger button assembly for a TIG welder. I did get lost on Digikey's website find a suitable product.  It has to be some kind of card edge design. Because I have to fit it in a torch handle so it must not be too far above or below the level of the PCB. That PCB is 1.6mm in thickness. That plug has a height of 5.5mm and a width of 11.5mm and a length of 9mm. A two position version would be ideal. And of course it is just for very low currents.
Thanks so much for your time.
goto considered awesome!
Offline w.v.s.
« Reply #1879 on: May 09, 2024, 03:16:54 pm »
This seems to go into a similar direction. Maybe some key words are helpful for your search.
https://eu.mouser.com/datasheet/2/123/333_008_500_101___EDAC_Card_Edge_Connector-2105857.pdf
Offline tszaboo
« Reply #1880 on: June 07, 2024, 03:19:03 pm »
The capacitor with the red markings. It has unusually large terminals, that I've never seen before. I expect some capacitor, probably NP0, which has stable frequency response up to 2 GHz, since it's an AC coupling part in a 2 GHz probe.
Anyone has an idea who is the supplier and the series? Is it an Agilent custom part?
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Offline tszaboo
Offline rsjsouza
  • Eternally curious
« Reply #1883 on: June 09, 2024, 10:51:14 pm »
Parts can be made available for vertical customers much earlier than to the general market, with the common secrecy/NDA involved. Besides, that is just AVX, but I wonder if other manufacturers might have released this type of component earlier.
Offline shakalnokturn
« Reply #1884 on: June 24, 2024, 09:30:39 am »
I'm having a little trouble identifying some SOP8 MOSFET's, I'm after the datasheets.
W204 dual N channel with typical pinout.
5139 single P channel with typical pinout.
Siliconix 3005 dual N+P.
« Last Edit: June 24, 2024, 09:33:38 am by shakalnokturn »
Offline fzabkar
« Reply #1885 on: July 03, 2024, 05:36:10 pm »
Several brokers are offering SI30058DY-T1-E3, but I can't find a datasheet.
The following users thanked this post: shakalnokturn
Offline gamalot
  • Correct my English
    • Youtube
« Reply #1886 on: July 05, 2024, 11:15:05 am »
I can't find any clues at all. It's almost the hardest thing I've ever seen!
Offline tszaboo
« Reply #1887 on: July 05, 2024, 02:00:49 pm »
I know, I have specific BOM lines in products, that are made for my company.
I was just wondering if this was an off the shelf part.
« Reply #1888 on: July 15, 2024, 10:52:34 pm »
Thanks for trying... So what was the hardest ever?
I can't remember for the Siliconix part but if I remember correctly the other two are pulled from equipment of the same era if not both from the same device which could have been some random old Sony design or an old hard disk including IBM / Maxtor / Sony./ Quantum.
Offline gamalot
    • Youtube
« Reply #1889 on: July 15, 2024, 11:06:08 pm »
I like identifying chips as a brain exercise, and I can solve them most of the time, but this one really knocked me out.  :palm:
Offline fzabkar
« Reply #1890 on: July 16, 2024, 01:31:09 am »
I thought those markings were familiar. This is an excerpt from my HDD/SSD IC database:
P-channel MOSFET, Sanyo, marking 5139, SO8 package, same pinout and specs (?) as PHK04P02T, dates from 2003
Edit:
FW204, Sanyo, 2 N-channel MOSFETs, 20V, 2A, marking W204, SOP8:
https://www.datasheetarchive.com/?q=fw204
https://hugepdf.com/download/etc-fw204_pdf
https://pl.aliexpress.com/item/1005004734904793.html (photo)
Edit #2:
Hahaha
It's an FSS139.
FSS139, Sanyo, P-Channel Silicon MOSFET, -20V, -4A, marking S139, SOP8:
https://pdf.datasheetcatalog.com/datasheet/sanyo/ds_pdf_e/FSS139.pdf
https://pl.aliexpress.com/i/1005004094240123.html (photo)
« Last Edit: July 16, 2024, 02:26:54 am by fzabkar »
The following users thanked this post: gamalot, shakalnokturn
Offline psysc0rpi0n
  • Country: ar
« Reply #1891 on: July 31, 2024, 10:58:48 am »
Hello.
I'm trying to find a battery charger controller chip in a device called LilyGo T-SIM7600X (or actually LiLyGo T-SIM7600G/H, the last chars are for zone identification) and the circuit schematic refers to a CN3065 DFN-8 chip (page 1).
I attached the circuit schematic below.
However, visually inspecting the board, I can only find 1 chip with 8 pins and I'm not sure the packaging is the one mentioned in the circuit schematic (DFN-8). It just says THY and looks like the image attched below. Could this be the mentoined chip that controls the battery charge process?
Offline gamalot
    • Youtube
« Reply #1892 on: July 31, 2024, 12:23:12 pm »
The chip in your picture is a CN3165 not CN3065.
Offline nali
« Reply #1893 on: July 31, 2024, 04:43:27 pm »
Hi
Trying to ID a through-hole diode. It's a glass package size 3.7x1.8mm as near as I can measure it. Marking is:
C18
5T
This is on an induction hob PCB, it's a protection diode between G&E of one of the main switching IGBTs which is in a single ended (common emitter) configuration, not part of a H-Bridge. Ideally I'd like to fit an identical part, though not the end of the world if I don't.
The part marking suggests it's a 18V zener, though the PCB legend indicates a TVS - although I take that with a pinch of salt as the IGBT is incorrectly marked as a MOSFET.
Offline gamalot
    • Youtube
« Reply #1894 on: July 31, 2024, 11:52:19 pm »
It could be an 18V Zener diode.
Offline psysc0rpi0n
  • Country: ar
« Reply #1895 on: August 01, 2024, 08:19:39 am »
Can you tell me, please, how can you tell it's one and not the other?
In fact, there is another detail I didn't tell but may be important. The schematic they have available in their Github says v1.2. In the board silkscreen it says v1.3 so it may have differences I don't know of and I can't find any other circuit schematic with the updated version v1.3.
Offline gamalot
    • Youtube
« Reply #1896 on: August 01, 2024, 08:38:36 am »
(Attachment Link)
Most of the time people can identify the model number of components by their top markings.
The following users thanked this post: psysc0rpi0n
Offline Mbre
« Reply #1897 on: August 01, 2024, 10:44:10 am »
I am trying to identify this object I think it is some kind of mosfet maybe I have tried to google it but with no luck
It is in a cable locator transmitter Rycom brand
I am hoping to buy
Offline madires
  • A qualified hobbyist ;)
« Reply #1898 on: August 01, 2024, 01:23:15 pm »
NCP1117, 1A LDO, adjustable
Offline gamalot
    • Youtube
« Reply #1899 on: August 01, 2024, 01:24:16 pm »
