Author Topic: What's this please? (Component Advice)  (Read 1268076 times)
Offline odessa
Re: What's this please? (Component Advice)
« Reply #1625 on: September 29, 2020, 01:38:17 pm »
Anyone have any idea what this is ? It's marked 9FS 5Y
Removed from a Kenwood head unit.
When  I die I want to die peacefully in my sleep like my Grandad ... Not all shouting and screaming like the passengers on his bus.
Online PA0PBZ
« Reply #1626 on: September 29, 2020, 02:29:23 pm »
The packaging looks weird, what is there on the right side?  :-//
It looks like one of these: https://www.torexsemi.com/file/en/products/discontinued/-2016/53-XC6209_12.pdf
(See page 28)
« Last Edit: September 29, 2020, 02:34:08 pm by PA0PBZ »
The following users thanked this post: odessa
Offline odessa
« Reply #1627 on: September 29, 2020, 02:46:51 pm »
Yes, it's a SOT89-5 , thanks !
Still not sure what voltage it is, that table is confusing  :D
Offline tsmith35
« Reply #1628 on: October 02, 2020, 12:11:05 am »
Looks like...
9 = XC6209xxxxxx series
F = XC6209Bxxxxx product series covering 0.15V to 3.05V in 0.05V increments
S = 2.4V to 2.45V output voltage based on the product series
The 5Y is the lot number.
Offline Shiv
« Reply #1629 on: October 14, 2020, 01:05:10 pm »
Hi all.
I´m with an 8116A with an offset at output.
We have found a faulty dual transistor:
HP p/n:1853-0589  -> MD4260
I don´t find anything about this on internet, no datasheet, no spares and no equivalent.
If anyone knows something about it, thanks in advice...
Online PA0PBZ
« Reply #1630 on: October 14, 2020, 01:28:51 pm »
Looks like 2 HF PNP's in one TO77 package: http://transistor-spravochnik.ru/description/md4260/44986
Online gamalot
  • Correct my English
    • Youtube
« Reply #1631 on: October 14, 2020, 05:17:41 pm »
Considering that 3.3V regulator is much more common, maybe it is an XC6223B331PR-G, see page 29:
https://www.torexsemi.com/file/xc6223/XC6223.pdf
Offline shakalnokturn
« Reply #1632 on: October 26, 2020, 11:03:58 am »
This TO-92 is in position "T3109" on a Hameg 205-3 oscilloscope's timebase.
The service manual shows it should be a BF256 JFET.
Supposedly defective because I was unable to get the start of the analogue and digital storage traces to coincide, replacing it solved the problem.
AVR transistor tester sometimes shows it as JFET sometimes BJT...
I can't find anything with the actual markings. Any clues?
Offline jchw4
« Reply #1633 on: October 26, 2020, 03:50:59 pm »
Could somebody help me identify this component?
This are photos of the output jacks of the Ronan x85 calibrator. The element is between "Output-" and "Output+".
It it a TVS? I can read 50V on it. Does anybody know the particular part?
Offline Nusa
« Reply #1634 on: October 26, 2020, 05:02:51 pm »
Axial lead glass ceramic capacitor. Your pictures don't have a good angle on the number that indicates value.
Here's an example: https://www.goldmine-elec-products.com/prodinfo.asp?number=G23426
You can also find them on ebay.
« Last Edit: October 26, 2020, 05:04:48 pm by Nusa »
The following users thanked this post: jchw4
Offline Snadman
    • RT-Ramblings
« Reply #1635 on: November 04, 2020, 07:27:04 pm »
Hey Dave,
I know this is a 4 year old post but I can identify that part for you.  It's a triac used in a Lutron TG-603PG 120V dimmer switch.  I tried calling Lutron to get any information on it since I haven't found any datasheets or schematics, but they said they didn't have that information.  I have one of these dimmers, so if you'd want pictures of the PCB to reverse engineer the pinout, I'd be happy to share.
Thanks,
Remy
Online PA0PBZ
« Reply #1636 on: November 04, 2020, 07:54:57 pm »
It would have helped a lot if you quoted the post you are replying to  :-\
Offline jogri
« Reply #1637 on: November 15, 2020, 05:22:11 pm »
Not so much a "what is this", but a "where the heck can i get it" question: It's a 5x20mm fuse holder with some sort of extension that makes the entire fuse holder longer. I considered just buying normal fuseholders for their insert, but those are not long enough (the fuse just bounces around inside)...
(I currently have one of those things that gets shared between a Keithley 236 and a AFG, so i need a second one)
Online PA0PBZ
« Reply #1638 on: December 07, 2020, 09:07:39 pm »
Any ideas about this H8Z1K thing? It's in a CE-19 interface for a Xiegu X5105 radio.
Offline PartialDischarge
« Reply #1639 on: December 08, 2020, 08:02:24 am »
It seems like this one
http://www.ic72.com/pdf_file/k/88872.pdf
Online PA0PBZ
« Reply #1640 on: December 08, 2020, 08:09:24 am »
Thanks, I found that too but I can't believe that a UHF tuner part would be used to switch a PTT line.
Online PA0PBZ
« Reply #1641 on: December 08, 2020, 10:08:31 am »
Offline shig
« Reply #1642 on: December 14, 2020, 12:13:42 pm »
I've never seen markings like this on a capacitor and a google search isn't being very helpful. I have quite a few of them but don't know what they are. All I know is that they were made in Mexico. Any help is appreciated. Thanks
Online PA0PBZ
« Reply #1643 on: December 14, 2020, 01:13:29 pm »
That looks like a varistor.
Online gamalot
    • Youtube
« Reply #1644 on: December 14, 2020, 01:51:37 pm »
It looks like a resettable PTC made by Littlefuse.
The following users thanked this post: shig
Offline shig
« Reply #1645 on: December 14, 2020, 06:29:41 pm »
Ah ok. I found those. I'm not familiar with them at all. I don't see a chart or legend on how to decipher code on it. Do you know?
Offline Nusa
« Reply #1646 on: December 14, 2020, 07:51:08 pm »
The logo is the one used by the TE Electronics/Tyco/Raychem brand for polyswitch devices. Littelfuse acquired that part of them about four years ago, which is why all the supplier links go there now, even if some of the pictures are old.
You can always test one to see what its trip current is. If it's in the label at all, I'd guess that 130 refers to 1.3 amps. The voltage rating is a bit harder to determine.
Offline blackbird
  • Ooohhhh, what does this button do???
« Reply #1647 on: January 22, 2021, 11:38:29 am »
Two unknown parts from my partsbin:
These two parts have a small note stating they are '7dB attenuators' and the note 'ptt'. The latter gives me the impression it is related to something to do with telephone technology, but I can be completely wrong. PTT used to be the national telephone operator here in The Netherlands.
Offline capt bullshot
« Reply #1648 on: January 22, 2021, 12:59:53 pm »
The circuit looks like an attenuator for a balanced line.
Offline CJay
« Reply #1649 on: January 22, 2021, 01:03:46 pm »
And very generously of the manufacturers, they left it unpotted so it should be possible to measure all the components.
