Author Topic: What's this please? (Component Advice)  (Read 1257304 times)
Offline Cyberdragon
Re: What's this please? (Component Advice)
« Reply #1200 on: June 17, 2017, 11:22:48 pm »
That's a bloody Nippon Chemicon! Check to see if it still works.
*BZZZZZZAAAAAP*
Voltamort strikes again!
The following users thanked this post: Gadgetman
Offline Gadgetman
  • Complete newbie to electronics - please be patient
    • Design & Drafting Solutions
« Reply #1201 on: June 18, 2017, 12:13:38 am »
I will sure check, but being a novice, I am not sure if you mean they are "indestructible" or "gold plated"  ;) and if they work, should I leave them as they are because of their brilliant reputation; or should I replace them? Bear in mind that they are 50 years old and even if they still work, should I trust them to continue to work and for how long?
Barefeet but still wearing spurs
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #1202 on: June 18, 2017, 11:56:09 am »
Nippon Chemi-chon capacitors have excellent reputation for durability. Despite this, the particular dielectric technology can have a limited lifespan regardless of the brand.
I hate replacing parts without need, but it is very difficult to properly test this capacitor throughout its voltage range of 1.5kV - you never know if it has a leak that manifests itself only after a specific voltage.
All in all, if you can spare the time you can leave the capacitor, repair everything else, reassemble the unit and test it - if it works well you leave it there but if it doesn't you have a suspect.
Offline nonsuchpro
    • YouTube
What's this please? (Optocoupler)
« Reply #1203 on: June 28, 2017, 10:57:44 am »
Hey all,
I was unsoldering some components off a board and "scored" 4 nice looking optocouplers while doing it. However, I'm having a hard time finding a data sheet for them. The numbers are easily readable but the only letter of the name I can clearly make out is the F at the beginning. It looks kinda like FyyD, FyyN, or from a distance it looks like Fury. The are all marked 735 in front and 6E in back. Anybody have any idea what they are? And maybe a data sheet or link to one? It would be much appreciated.
Thanks in advance!
Rob
Offline Bendba
« Reply #1204 on: June 28, 2017, 11:12:25 am »
Hi.
Might be a silly question but, are you sure they are opto's?
Stop dreaming your life, start leaving your dreams.
Offline Gromitt
Re: What's this please? (Optocoupler)
« Reply #1205 on: June 28, 2017, 11:43:39 am »
Hey all,
Thanks in advance!
Rob
Not an F, it's in japanese and says Moririca (Moririca Electronics Ltd) and according to Google it is a optocopler and called MCD735, but that is all I can find on the net with my five minute search.
/stefan
The following users thanked this post: nonsuchpro
Offline nonsuchpro
    • YouTube
« Reply #1206 on: June 28, 2017, 11:43:53 am »
Hi.
Yes without a doubt. I have other optos just like it. You can look at the legs and tell the LED on one side and the CDS on the other.
« Last Edit: June 28, 2017, 11:48:24 am by nonsuchpro »
Offline nonsuchpro
    • YouTube
« Reply #1207 on: June 28, 2017, 11:46:24 am »
/stefan
Ah OK. Thanks. I typed all kinds of things in google. I would have never thought it might be Japanese writing.
« Last Edit: June 28, 2017, 11:48:49 am by nonsuchpro »
Offline IanMacdonald
    • IWR Consultancy
« Reply #1208 on: June 28, 2017, 11:56:33 am »
In every CRT monitor or TV I have taken apart, there was this odd inductor that has a permanent magnet glued to it. Is that to offset the magnetic field generated by a DC bias current so a cheaper core can be used?
Yes, that's what it's for, the permanent magnet biases the inductor to oppose the DC current so a smaller, cheaper core can be used.
Might be, but might also be line linearity correction. Magnet causes the inductor to saturate in one current direction only, giving more current on that side of  scan. Some have a rotatable magnet for adjustment.
Online Gyro
« Reply #1209 on: June 28, 2017, 12:05:12 pm »
Those look like LDR (light dependent resistor) type, driven by a visible LED. The LED pins are the thick ones and the LDR the thin ones.
Try applying current to the LED (correct polarity) over a 0-20mA range and monitor the LDR pins on the Ohms range of your DMM. If you see a varying resistance which is the same when you reverse the connections then it is an LDR.
They're useful for control of AC signals, for instance, volume controls or amplitude feedback in a low distortion Wein Bridge oscillator. Here's a generic app note:
http://www.perkinelmer.com/CMSResources/Images/44-3429APP_AnalogOpticalIsolatorsAudioApps.pdf
Try looking up Vactrol too, I think they make them.
P.S. Once you have an idea of the resistance range then you probably don't care much about the specific datasheet. But don't go above 20mA on the LED.
« Last Edit: June 28, 2017, 12:08:10 pm by Gyro »
Best Regards, Chris
Offline nonsuchpro
    • YouTube
« Reply #1210 on: June 28, 2017, 12:47:22 pm »
Yeah. Like I said I definitely know what it is. I have tested it. I just cant read the name so I can download the data sheet .pdf, that's all.
Thanks!
Offline nonsuchpro
    • YouTube
« Reply #1211 on: June 28, 2017, 12:50:43 pm »
I forgot to mention the acronym LDR. LDR is a CDS Photoresister.
Offline Bendba
« Reply #1212 on: June 28, 2017, 12:56:25 pm »
Looks like you might have to do specs measurement yourself. Can't seem to find a readable datasheet either  |O
What did I miss about this 6 years old post resurfacing?
Even though the comment is perfectly pertinent.
Offline nonsuchpro
    • YouTube
« Reply #1214 on: June 28, 2017, 02:19:30 pm »
There is a cross reference here
https://www.tube-town.net/ttstore/Parts-for-Amps/Optocoupler/Tesla-Optocoupler-3WK-163-40::7720.html?language=en&MODsid=7ecjqtf8cus0a47u8nc0mgu8d7
Google results for the cross reference
https://www.google.com.au/search?site=&source=hp&ei=jK5TWaHxJ4i30QT6h7ugAQ&q=vtl5c1+datasheet&oq=VTL5C1&gs_l=mobile-gws-hp.1.2.0l5.1625.1625.0.3705.3.2.1.0.0.0.263.263.2-1.1.0....0...1.2.64.mobile-gws-hp..1.2.312.3..35i39k1.GITtfNNTRuE#xxri=0
Direct link to a datasheet
https://www.google.com.au/url?sa=t&source=web&rct=j&url=http://logosfoundation.org/instrum_gwr/playerpiano/Optor_VTL5C1_87223.pdf&ved=0ahUKEwj8ndmT0uDUAhXMJpQKHTQHDlsQFggkMAA&usg=AFQjCNHQWDC5cWHVx0bgbrtn-8sv4cGE-A
Wow Awesome, You da man!
I make Vactrols, Optocouplers all the the time. I have way more of my own than bought because they are so easy to make.
For those who don't know, you just point a YELLOW LED (for best results) at a LDR (CDS Photoresister) and heat shrink tube it. Or find little things you can use like pens and such. I've hollowed out capacitors, round fuse holders, even just wrapping black electrical tape works in a pinch. Anything completely lightproof will work.
Thanks a million Bendba!
Rob
« Last Edit: June 28, 2017, 10:26:12 pm by nonsuchpro »
Offline Bendba
« Reply #1215 on: June 28, 2017, 08:55:14 pm »
No worries, glad it helped.
Offline stennic
« Reply #1216 on: June 29, 2017, 09:23:10 pm »
Hi!
Found the mystery component in an intercom system, and none of us could figure out what it is. The one we can't figure out is the 4-pin, white thing next to the 8-pin smd relay between the two resistors (the board has two identical setups on either side). The silver-colored stuff in the middle reminded me of an LED, with two asymmetrical halves separated by a narrow gap, but that wouldn't make sense. The function of the board is to switch a microphone signal and ptt-button signal from one input to one of two radios depending on the position of an external switch.
Hope my explanation is not too confusing, being quite exhausted after over 20 hours of work on the intercom system...
Offline bktemp
« Reply #1217 on: June 30, 2017, 04:52:49 am »
That is clearly a LED or some other opoelectric component.
OSRAM calls this package style SIDELED:
http://www.osram-os.com/Graphics/XPic3/00090950_0.pdf
Offline stennic
« Reply #1218 on: June 30, 2017, 06:41:49 am »
It quite clearly is, despite serving no apparent reason in there... Thank you!
Offline bktemp
« Reply #1219 on: June 30, 2017, 06:55:50 am »
Sometimes LEDs are used as low voltage zener diodes (zener diodes below 4V typically have a very soft transition, LEDs have a much steeper current slope).
But in this case based on the position next to the relay I would assume they show the active relay.
Offline stennic
« Reply #1220 on: June 30, 2017, 07:03:30 am »
My guess was also to show which relay is active, but being mounted under another board in an IP67 box, they can't be seen once the box is mounted (which has to be done before connecting the external wiring). But then again this whole rats nest was made by a "professional" company specialized in communications systems, so who knows what they were thinking...   :-//
Offline JPortici
« Reply #1221 on: June 30, 2017, 11:52:38 am »
Being desperate to find spares for this
it's a dual gang potentiometer... with endless rotation! used in lecroy test equipment
Offline nonsuchpro
    • YouTube
Re: What's this please? (Power Cable Safety Clip?)
« Reply #1222 on: July 06, 2017, 05:43:09 am »
Hi all,
Everyone in the world has seen these but I've been googling stuff like "Power Cable' Safety Clip, Security Clip, Cable Stop, Pull Stop, etc. and can't find what I'm looking for. I've destroyed at least 50 of these with pliers and a flat head over the years. I'm kinda embarrassed I don't know what they are. (See pic)
So I got a couple questions:
1) What are they actually called?
2) Whats the best way to open/remove them?
Thanks in advance!
Rob
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #1223 on: July 06, 2017, 05:46:33 am »
They are called strain reliefs.  There are special pliers made for installing and removing them, though being cheap I've had success using a big end nipper.
-Pat
