Hi, I've been looking for hours on Mouser, Newark and Digikey for a part number for this connector so I can buy its harness, crimpable terminals, etc. for them. I'm not sure if this connector is considered an automotive one, but the board is used in an automobile. Any help to find a part number or source for them would be greatly appreciated.
I've been down the road of trying to identify and locate unknown car electrical connectors. It's not an easy job.
A start would be to narrow-down who the potential manufacturers of the connector are. Which make of vehicle does this come from? If one assumes a US domestic manufacturer, it's most likely that the connector will also be made by a US company. If it were, for example, a Japanese car, I would look at the Japanese connector manufacturers. Are there any markings embossed in the plastic? Look closely, as they may be tiny, or may look inconsequential.
Another way to narrow-down candidates is to ascertain the specifications of the connector. Measure the width of the terminals. Measure the space/pitch between terminals. Also the spacing of the pins on the PCB. If it's for a USDM manufacturer, there's a chance it's a USCAR-standard-compliant connector, so more than one manufacturer may produce something matching.
Also, there is a good likelihood that the entire module was made a 3rd-party supplier, and in fact uses a proprietary connector only made by that 3rd-party company. I have seen this on some cars where all the connectors on the harness are made by one major manufacturer, but at the points where it connects to a dash/window/audio module made entirely by a supplier, they use the supplier's own connectors.
Finally, what year is the vehicle? If it's more than 10-15 years old, I wouldn't put much faith in that particular connector being made any more. Especially for wire-to-board connectors (as opposed to wire-to-wire), as those tend to be for more specific applications that live/die with the lifetime of the vehicle model.
