Hello,
I'm a proud owner of a JBC HD-2B soldering station.
![](https://www.jbctools.com/productes/HD/img/tam_1/imagen_01.jpg)
This station comes with the T470 handles and they are using the C470 tips.
Those C470 tips are nice, but if you want to do some finer work, a T245 with C245 tips would be much better.
Unfortunately, the T245/C245 is not compatible with the HD-2B. Except, if you
put a 60 Ohm resistor in the +Ub path when using a T245/C245.
I have found this in the German "mikrocontroller.net" forum:
https://www.mikrocontroller.net/topic/408786#4791503I'd like to build a switchbox, where I can switch between the T470 and T245
and for this I need to know, what the connectors are.
The HD-2B comes with a cable, which connects the power supply to the stand for the T470.
The cable has the item number 0011283 and is looking like this:
![](https://i.imgur.com/utWISmp.png)
Does anybody exactly know, what the connectors are?
Thank you for your help.
Mounty
