Author Topic: What's this please? (Component Advice)  (Read 1257287 times)
0 Members and 11 Guests are viewing this topic.
Online gamalot
  • Correct my English
    • Youtube
Re: What's this please? (Component Advice)
« Reply #1425 on: September 20, 2018, 12:12:19 pm »
After some more intensive digging, I think it may be ATF-10136. Is it possible? The datasheet does not state the package marking.
https://www.qsl.net/n9zia/trans/ATF10136.pdf
On page 3.
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #1426 on: September 20, 2018, 08:20:31 pm »
Oh god  :palm:
I did not notice that. I have just skimmed through and searched for "marking" as usual. My bad, sorry.
Offline jaromir
  • Country: sk
« Reply #1427 on: September 22, 2018, 07:33:42 pm »
I received two pieces of this devices from a friend and I'm really curious to know what it is. Can anyone help me identifying those, please?
It is apparently soviet device, made in autumn 1975, that's all I can tell. SD adapter included for scale.
Online gamalot
    • Youtube
« Reply #1428 on: September 23, 2018, 03:10:19 am »
Oh god  :palm:
I do exactly the same thing, search by keyword "marking" in datasheets.  ;D
Offline Cyberdragon
« Reply #1429 on: September 24, 2018, 04:44:52 pm »
They appear to be ICs, the soviets made some weird stuff.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline jaromir
  • Country: sk
« Reply #1430 on: September 24, 2018, 06:02:38 pm »
Yep, they made a lot of weird stuff. I cut my teeth on electronics stuff made on eastern side of iron curtain.
Thanks for your guess; looks like we have similar thoughts. That packaging looks phenolic-resin-ish, perhaps some hybrid stuff? My other guess is passive network. I'll wait for a while and then perform measurement and vivisection of the object.
Offline shakalnokturn
« Reply #1431 on: September 27, 2018, 11:41:58 pm »
I stumbled on these sorting through my stash before moving, I'd be interested in any information on the STC microwave sources.
Offline robjodicarter
« Reply #1432 on: September 29, 2018, 08:06:45 pm »
Could someone name the components on here please, u want to try and build one of these but I don't know what the components are please help me.
Thank you
Rob
Sent from my PH-1 using Tapatalk
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #1433 on: September 29, 2018, 10:10:33 pm »
Well, the most that can be done with the photograph that does not show any part numbers (at least I couldn't see them) is to go with what it is usually used in such designs: the large IC is a preprogrammed microcontroller (which you will probably never be able to obtain the programmed firmware), the bottom left part is a voltage regulator (most probably a LM1117 or something like that), the top larger black part above the microcontrollee is a crystal oscillator and all the six pin parts are drivers or transistor pairs (probably MOSFETs).
Assuming that you didn't design this to be asking such question, I think a much fairer scenario is to either reward who designed this by buying their product or try and create your own product instead, don't you agree?
https://www.ghoztlighting.com/product/ledsequencer/
Offline djos
« Reply #1434 on: September 29, 2018, 11:13:04 pm »
Hi All, are these IDC wire-to-board Connectors? I cant find a consistent name for them
https://protostack.com.au/shop/connectors/idc/10-pin-idc-ribbon-connector-breadboard-friendly/
I'm looking for a source for 28 Pin DIPP versions suitable for old ROM Sockets for a Clock Board project - I've created a replacement for the old Tandy SmartWatch modules with a replaceable CR1632 lithium cell for the EX models (which never worked with the OEM units due the location and height). A few folk who own other models want a version of my adapter for their systems (the Originals have potted batteries and are mostly dead) - I was hoping I could use a ribbon cable adapter solution for the other systems.
Adapter with ROM Bios Chip Installed:
Inserted into ROM Bios Socket on an EX:
« Reply #1435 on: September 29, 2018, 11:34:04 pm »
 I understand buying their components but when they charge 250 for it. Just hard to justify. I'll just write code to an Arduino. Was just trying to get an idea of what the chipset was.
Thank you
Rob
Offline Nusa
« Reply #1436 on: September 30, 2018, 02:54:35 am »
We simply can't tell you what we can't see. You haven't provided a picture of sufficient resolution to read any chip markings. Nor did you transcribe them for us. The general answer you already got is about as good as it gets from those pictures.
Offline amyk
« Reply #1437 on: September 30, 2018, 03:29:40 am »
It's probably a 44-pin PIC. The 6-pin programming header with GND on pin 3 and the two data/clock lines on 4 and 5 strongly suggest it.
Offline tanveerriaz
  • Country: pk
« Reply #1438 on: October 01, 2018, 04:02:39 pm »
Help to recognize lcd use in LOGIK model L3DAB12
Online gamalot
    • Youtube
« Reply #1439 on: October 01, 2018, 05:30:49 pm »
It's a PIC24F32KA304  :)
Offline orbiterTopic starter
  • -0 Resistance is Futile
« Reply #1440 on: October 04, 2018, 04:07:56 pm »
I'm trying to figure out the part number on this please guys so that I can get another one. It seems there maybe letters missing at the start?
It's on the output side of a Dyson Rechargeable vacuums charger.. Anyone know what it is please.
One page lead me to an Analogue Devices part but the package type was wrong.
It's DIP8 package however it only has 7 legs. Leg 6 is not present and legs 7+8 are joined together.
« Last Edit: October 04, 2018, 04:11:08 pm by orbiter »
Offline helius
« Reply #1441 on: October 04, 2018, 04:13:45 pm »
The following users thanked this post: orbiter
« Reply #1442 on: October 04, 2018, 04:17:32 pm »
Thanks very much mate, your a star  :-+
Offline PointyOintment
  • ↑ I scanned my face
« Reply #1443 on: October 04, 2018, 09:46:33 pm »
I just picked up a load of chips and stuff like that, Some I can find out what they do on parts.io but no idea on how to offload them as I have no use for them.
Like a 2KG Bag of PIC12C508P-04 Micro Controllers  :-//
20 Zilog Z8430ADS  :palm:
12C508: PIC microcontroller
Make a hardware neural net, like NeuroBytes?
Quote from: VinzC
27C2001: 1Mbit as 128K x 8bits EPROM (UV erasable)
You can use these as terrible solar cells. Make an impractical solar panel. Or put some known data pattern on them, and expose them to various kinds and doses of radiation as a longevity experiment.
Quote from: VinzC
A bunch of Z80A microprocessors
Sell them individually to people restoring old computers, arcade machines, and industrial gear?
Quote from: VinzC
8259: Interrupt Controller for (old) Intel architectures, like PC-AT
µA324: long before it was called LM324
Quote from: VinzC
MCM6810: 128 x 8-bit RAM
MCM60L64: 8K x 8-bit SRAM
Use them for processing? Make an array of rams, connect the data output back into the address input, and fill with specially designed patterns (read: program your new processor). Look up sdramThing—that guy made a logic analyzer with output to a large LCD panel out of ram.
Quote from: VinzC
6850: Serial interface (RS232)
RS 140-013: maybe a quad op-amp, 14pins (resistor array seems unlikely in packs of 7)
Quote from: VinzC
EDIT: On a second thought, maybe Fran Blanche would be interested in getting some as she has very nice & didactic tutorials on vintage technology. Maybe you can just ask her if you wonder what to do. Just suggesting.
I doubt she'd want all of them. Maybe one to a few of each. Good idea though. Edit: Probably not while she's dealing with being evicted.
« Last Edit: October 15, 2018, 02:37:22 am by PointyOintment »
I refuse to use AD's LTspice or any other "free" software whose license agreement prohibits benchmarking it (which implies it's really bad) or publicly disclosing the existence of the agreement. Fortunately, I haven't agreed to that one, and those terms are public already.
« Reply #1444 on: October 15, 2018, 02:36:27 am »
I finally have something to ask the oracles about. (I was planning to ask about a chip that looked like a current sensor, but that disappeared before I could.)
This device appears to be some kind of light sensor. It has no markings that I can see. I found it on the floor by an electronics recycling bin that people look through for parts. The chip and two capacitors are mounted on FPC, which is mounted on a stamped (?) aluminium piece, which has some glue on the back. It's a hard, white, translucent glue that I've seen in optics before.
From the top, with the loose ends of the FPC facing me and the sensor facing up, the traces go like this: 1 narrow, 2 wide, 7 narrow on the left; 6 narrow on the right. One capacitor is across the two wide traces (so those are likely power and ground) and the other capacitor (the angled one) is from one of the wide traces (probably ground) to a trace that goes under the chip. The one narrow trace on its own wraps around to the other side of the chip. The loose ends have some markings as if they're inserted into connectors that far, but no copper is exposed, and the edge appears to be torn—it's not quite straight and square on either side.
Pictures 1–3 show it on some painter's tape. Picture 4 shows it on a USB standard-A plug for scale. Picture 5 was taken with a USB microscope.
Offline amyk
« Reply #1445 on: October 15, 2018, 12:06:56 pm »
I agree, it's a BGA light sensor. No idea of the application, however.
« Reply #1446 on: October 15, 2018, 05:23:43 pm »
Optical detector for a DVD or CDROM drive, the bit used to recover the data from the reflected light.
The following users thanked this post: Richard Crowley
« Reply #1447 on: October 15, 2018, 08:21:54 pm »
I suspected that due to the construction, but I've never seen one quite like this in my disassemblies. I'll have to keep my eyes open for them.
Offline PartialDischarge
« Reply #1448 on: October 22, 2018, 01:15:49 pm »
No idea what this is although I looked, I guess memory or something related to a uP
Online PA0PBZ
« Reply #1449 on: October 22, 2018, 01:26:30 pm »
This is the first time that the datecode actually is the product code  ;D
http://www.ti.com/lit/ds/symlink/lmx9830.pdf
The following users thanked this post: PartialDischarge
