Author Topic: What's this please? (Component Advice)  (Read 1257273 times)
Offline tautech
Re: What's this please? (Component Advice)
« Reply #1375 on: June 27, 2018, 08:30:34 pm »
THz, that's just cotton covered magnet wire if I'm not mistaken. I'd be surprised if it's still available.
Temp stable resistances were often wound from Constantan, a wire similar to nichrome.
If one will power up it might be a good idea to measure the current and voltage across it and let that guide your choice of replacement resistance wire.
Offline TerraHertz
    • It's not really a Blog
« Reply #1376 on: July 06, 2018, 01:00:58 am »
Given what the instrument is, what it probably cost new, and that these resistors range from 500 R to 5K, and that the circuit is a precision resistive bridge to measure glass photodiode current by nulling, I very much doubt they are ordinary magnet wire.
Ah! Constantin. Yes, thanks, that's the word I couldn't remember.  Next question is whether that wire in any suitable form is still available. Having the keyword helps.
Actually due to the circuit arrangement, with stuff unplugged all these resistors have at least one end isolated, so can be measured directly. Determining their values is not a problem. And I guess I can hot air them while measuring, to roughly estimate temp coeff. to see if it's some ordinary wire or something like Constantin.
"See if it will power up" - Heh. The entire thing runs on two D cells. Directly. Though the photocell circuit actually has some electronics, the rest is ultra simple. Except for being a tangle of connectors and a multi-pole, multi-position range & mode switch, that makes converting my traced circuit mess into a sensible schematic, non-trivial.
Today's unrelated question: does anyone have data on these old hockey-puck SCRs? (See pics)
I was just given three SCR & inductor modules. Two of the SCRs are marked westinghouse T920100803DW 7526.
The third one looks physically identical but is marked  PSI 1000 10 MJA 2.
The round end contact faces are 44mm dia.
I'm hoping to find data sheets, mainly for curiosity.  Judging by the medium degree of surface corrosion they are probably quite old, so nothing special specs-wise.
Slight bummer: The one I took out of the tensioning frame to clean, the number rubbed off the ceramic with the very first light wipe. It's apparently just black ink on glass-smooth ceramic, as opposed to glaze baked onto the ceramic. Dammit.
« Last Edit: July 06, 2018, 07:16:01 am by TerraHertz »
Offline amyk
« Reply #1377 on: July 06, 2018, 02:14:18 am »
Offline tautech
« Reply #1378 on: July 06, 2018, 05:37:10 am »
Given what the instrument is, what it probably cost new, and that these resistors range from 500 R to 5K, and that the circuit is a precision Wien bridge, I very much doubt they are ordinary magnet wire.
Wiki has a bit about Constantan and it's cousin Manganin
https://en.wikipedia.org/wiki/Constantan
https://en.wikipedia.org/wiki/Manganin
Offline TerraHertz
« Reply #1379 on: July 06, 2018, 06:41:42 am »
The datecode on that SCR is 26th week 1975. It's a 1kV, 800A, 250us 200mA version.
Look at page 354 of this: https://archive.org/download/bitsavers_westinghouinghousePowerSemiconductorUsersManualand_67287821/1978_Westinghouse_Power_Semiconductor_Users_Manual_and_Data_Book.pdf
Holy carp.
That's a fascinating data book too, thanks.
Wish I could have seen whatever 'thing' these inductor-SCR assembies came out of.
It's so typical, that whoever disassembled it just cut off the firing leads short of the original ring lugs. Lazy SOBs.
Now, to  rig up some kind of test circuit to at least see if they are functional at a small fraction of their rating.
The clamping brackets have an interesting integral tension indicator.
A thin indicator bar is rigidly attached to one end of a thick spring tensioning bar. As the spring tensioner gets bowed by applied force, notches at the other end of the indicator bar line up with the end of the tensioner bar.
1st pic shows a tensioned set, 2nd pic one with no tension.
Edit to add: 3rd pic shows the dome-pivot in the central spacer post. Resulting in equal pressure distribution across the SCR puck faces, regardless of unequal screw-down of the tensioning nuts.
2nd edit: Hmm. There's that date bug in Advanced Renamer utility again. Every now and then it gets the 'date photo taken' wrong. Those pics should all be named 20180706_whatever... Sigh. Bug fix hunting time.
« Last Edit: July 06, 2018, 07:43:45 am by TerraHertz »
Offline exit_failure
« Reply #1380 on: July 09, 2018, 08:47:11 am »
So I bought a bag full of old components predominantly out of GDR production. Most of it I could identify but there is this connector I can't make heads or tails of it and what it was used for.
It has a 5-pin DIN style connector on top and another square, spring loaded connector beneath it. The second connector has a removable plastic cover.
The ruler is in centimetres.
Offline Nusa
« Reply #1381 on: July 09, 2018, 09:39:26 am »
I don't think the red part is a connector at all. It's more likely a DPDT pushbutton switch. Momentary, unless you tell us it has a latching action. Perhaps it's meant to be used as a lid switch for whatever case it's mounted on? In which case the plastic bit is just a shipping item to keep the parts together.
The following users thanked this post: exit_failure
Online PA0PBZ
« Reply #1382 on: July 09, 2018, 09:50:00 am »
That 5 pin DIN connector was used for headphones (e.g. Philips) some 40 years ago.
« Reply #1383 on: July 09, 2018, 10:23:42 am »
There are always 4 of the six pins of the lower connector commoned together. Which ones depends on if its pushed in or not. It is momentary. (see picture) Both connectors are positively clipped/moulded into the red plastic casing and is doesn't look like the are meant to be removed from it.
Online PA0PBZ
« Reply #1384 on: July 09, 2018, 10:39:03 am »
So there you go: inserting the headphone plug switches the speakers off :)
I remember these plugs had a little metal square missing on one side, so you could either insert it to switch the speakers off or reversed to keep them on.
« Reply #1385 on: July 09, 2018, 10:50:16 am »
That makes sense. I actually like the way they did it. It's to be quite robust although switch the speakers on or off that way probably caused a lot of crackling and scratching.
I think these are for stereo systems since the left and right side are symmetrical. They are also only commoned together in pair and not all four of them, which kinda makes sense for stereo audio.  ;)
The Cover seems to be protection only as it doesn't push the switch in far enough to engage it.
Thanks for your help.
« Last Edit: July 09, 2018, 10:53:32 am by exit_failure »
Offline djQUAN
  • Country: ph
    • My DIY website
« Reply #1386 on: July 12, 2018, 01:26:15 pm »
Blew up a chinese 24V to 12V 40A converter (but eventually managed to fix it with unconventional parts - see http://www.quan-diy.com/misc/charger/se460.htm if interested) but is wondering what half bridge driver they were using.
It is a DIP8 device marked "3211P", has a single input, high side and low side outputs.
Googling doesn't reveal much info most results produced drivers from LT and IR and other random stuff.
It is used in a synchronous rectified buck converter with a TL494 doing the PWM duties.
Tracing the PCB I was able to identify which pins do what (see 3rd pic)
pin# - my label - description
1 - V+ - low side gate supply voltage
2 - IN - control input
3 - GND - low side negative/common
4 - OL - low side output, low side mosfet gate
5 - NC - not connected in circuit
6 - VL - negative of bootstrap supply, source of high side mosfet, connected to inductor input
7 - OH - high side output, high side mosfet gate
8 - V+H - bootstrap supply +, supply for high side mosfet driver
Thanks in advance.
Online gamalot
  • Correct my English
    • Youtube
« Reply #1387 on: July 12, 2018, 05:00:42 pm »
IMP3211 (datasheet in Chinese)  :)
http://www.icdemi.com/manual/IMP3211.pdf
The following users thanked this post: djQUAN
Offline djQUAN
  • Country: ph
    • My DIY website
« Reply #1388 on: July 13, 2018, 01:37:15 am »
Offline djos
« Reply #1389 on: July 15, 2018, 11:36:21 pm »
So Im completely stumped as to what this part is, mainly because I cant measure it - likely I killed it while extracting the pot from around it with 300c from my heat gun. I assume it's a cap but as it's dead (not even continuity) I cant get any readings out of it at all - to make matters worse, there are no visible marking of any kind anywhere on it.
Any ideas?
Online oPossum
« Reply #1390 on: July 15, 2018, 11:42:33 pm »
32.768 kHz crystal for the RTC in that module.
The following users thanked this post: Richard Crowley, salbayeng
Offline djos
« Reply #1391 on: July 16, 2018, 01:51:39 am »
Legend, I couldnt find that info anywhere.  :-+
« Reply #1392 on: July 30, 2018, 07:35:31 pm »
Potted battery, looks like a Dallas timekeeper ( now a Maxim part), and they almost always had a clock in them along with the RAM, and those are almost always 32.768kHz in that case, being the most popular value. Only rarely are they other frequencies, but if it was a RTC it will always be the 32768Hz to divide down easily to 1Hz
Offline djos
« Reply #1393 on: July 31, 2018, 06:30:14 am »
Cheers, knowing what that is has allowed me to reverse engineer it properly.  :-+
Online Gregg
« Reply #1394 on: July 31, 2018, 03:39:03 pm »
Holy carp.
I remember seeing these in an old Exide model 3180 ferro-resonant 480/277 volt 3 phase 180KW UPS.  It was huge, heavy, inefficient and very loud. It was scrapped years ago even though it still worked due to inefficiencies and maintenance of an obsolete system.
Maybe the reason you have three of these is that somebody removed them from some old UPS and thought they would get around to playing with them someday [it happens to all of us].
Offline scuzzyTerminator
« Reply #1395 on: August 03, 2018, 02:11:38 am »
This thread is slow and I got a new cheap microscope, so...
Found a few of these on the dollar cart and had no idea what they were, although the first picture makes me think they might be antennas.
(Those are millimeters)
Anybody know?
« Last Edit: August 03, 2018, 02:13:23 am by scuzzyTerminator »
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #1396 on: August 03, 2018, 08:14:10 am »
http://www.richardsonrfpd.com/Pages/Product-Details.aspx?productId=921206
Does not look as clean as the genuine part on the site images though.
He’s like a trained ape. Without the training.
The following users thanked this post: scuzzyTerminator
Offline timelessbeing
« Reply #1397 on: August 04, 2018, 04:26:21 am »
A fractal wifi antenna. Look like a PCB with many many layers. Fascinating. I wonder what an xray would look like.
« Reply #1398 on: August 04, 2018, 07:11:54 am »
Looks like FR-4 with a top layer and vias to pads on a bottom layer. Do you think there are middle layers?
I'd like to cut one up but don't have a lot of tool options. Suggestions?
Offline Cyberdragon
« Reply #1399 on: August 06, 2018, 07:10:13 pm »
Put it in a toaster oven on high for a long time and maybe it will delaminate.
*BZZZZZZAAAAAP*
Voltamort strikes again!
