Author Topic: Chinese solder wire brands?  (Read 27261 times)
Online Monkeh
Re: Chinese solder wire brands?
« Reply #75 on: November 04, 2024, 05:41:13 pm »
Having said that, I do accept that a different iron and different brand of lead-free solder might well change my opinion.
Well then, I suggest picking up some samples of SN100C-like solder, Felder comes highly recommended, I find Weller is perfectly acceptable and locally available, and trying them out. You can get a little sample pack for about £8. Apart from needing a little more heat (including a touch more dwell time with more mass), I think you'll be pleasantly surprised. I find no reason to reach for leaded solder unless I'm working on a board already using it.
The following users thanked this post: SteveThackery
