Author Topic: Hot Bar Bonding thermode  (Read 1354 times)
Offline JaneTopic starter
« on: September 04, 2014, 07:20:54 pm »
Hot Bar Bonding is achieved by using a thermode or "Hot Bar" which is heated and cooled under pressure using either a pulsed heat or constant heat reflow soldering power supply, creating an electrical connection between the materials joined.
Question:
is a thermode the same if used  a pulsed heat and  constant heat? Or a thermode MUST be differerent for pulsed heat and constant heat?
