(I'm cross posting because I couldn't get an answer where I asked before.)
Hello,
I've search the web, browsed digikey a bit, but I've not been able to identify the below pictured connectors.
There's a server PSU connector example listing here .
The other is a small 75W transformer. It has 4 connectors which I couldn't find. The 5th is a JST connector with one small black wire poking out of it.
I took some measurements of it. The pins are 1.25mm wide. The 6p connector is ~24mm long and ~6mm wide. The other three are also ~6mm wide with the 4p being ~17mm long and the 3p being ~12mm long. The reverse latching 3pin connector is ~12mm long by ~7mm wide.
Anyone know how to find connectors like these/what they are?
Thanks!
