Take it aapart!!!!
Not yet ..
Its like a new car, in the begging you have to find how the gear lever works, and where is hidden the damn astray ..
Where is the lights switch .. etc
Its a huge unit, just a bit smaller than a Fluke 28II .
The LCD light its more powerful than flashlight.
The 500,000 counts mode, its wonderful and its damn accurate.
The test leads are truly well made , silicon and soft rubber everywhere.
The test leads cables speaking about diameters and softness, are 100% comparable with the Fluke TL71 that does not come as standard tests leads.
The test leads tips are gold plated, and can be easily modified to work as:
1) totally exposed
2) covered with insulator caps (1000V measurements)
3) They get converted to banana plugs by additional screw on the tips accessories.
About the last one I was feel envy for long time about the Gossen Metrawatt test leads, but the Brymen offer all those choices, in a single set.
You have my promise to post 2-3 good images prior my full review, that needs as usual the 30 days test stress time.
