Author Topic: HELP... Trying to Identify this IC Chip. LCBNN481827  (Read 1212 times)
Offline iRepairElectronicsTopic starter
« on: December 22, 2020, 05:09:40 pm »
Can anyone help me identify this IC?  number on chip is LCBNN481827
Here's a pic if tit helps.
Offline axemaster
Re: HELP... Trying to Identify this IC Chip. LCBNN481827
« Reply #1 on: December 22, 2020, 05:13:28 pm »
A wider-angle shot around the IC would help us understand what kind of circuitry is surrounding it.
Offline bdunham7
« Reply #2 on: December 22, 2020, 05:20:20 pm »
What is it in and do you have any idea of its function?  I don't recognize it, but from the way it is connected, it may be an inductor or sensor of some kind, not a typical IC.
« Reply #3 on: December 22, 2020, 05:27:21 pm »
here is another angle.
its purpose is unknown to me as well. i have one that is smoked in another unit.
the unit its from is an item attached to a film camera. its prosperity and it would be useless to really attempt to go into to here.
it from the mid 90's and there is no schematic.
i know this will be a tough nut to crack. but looking at how so many pins are tied together
im thinking mosfet? some kind of switch ?
Offline Nusa
« Reply #4 on: December 22, 2020, 05:33:30 pm »
My first glance guess would be a mosfet, or similar. Figuring out where those triple-traces end up may answer what it is for.
« Reply #5 on: December 22, 2020, 05:38:28 pm »
in the second photo those 3 tied together end up right in between the 2 resistors just below it.
Offline Nusa
« Reply #6 on: December 22, 2020, 06:54:24 pm »
If the trace ended at the via, there wouldn't be much point, would there?
« Reply #7 on: December 22, 2020, 07:26:19 pm »
in other words that Via is Connected in between the two resistors.
Online amyk
« Reply #8 on: December 22, 2020, 10:08:50 pm »
LT3080
Seller image for confirmation: https://www.aliexpress.com/item/4000056510652.html (attached below as well.)
Offline tooki
« Reply #9 on: December 22, 2020, 10:22:29 pm »
Searching for "lcbn smd" quickly told me it's an LT3080.
Ah, while typing, I see amyk came to the same conclusion.
It's NEVER "useless" to provide information to the people from whom you are asking for help. And you should darned well make an effort to write clearly and without errors.
It took me, like, 3 minutes. So no, not that tough to crack. Practice googling for partial part numbers/markings, and with the right additional keywords (like "smd") to put Google on the right track.
How do you repair electronics if you don't even understand what a via does?
« Reply #10 on: December 23, 2020, 01:17:36 am »
Where you getting the idea i don't know what a via is?
« Reply #11 on: December 23, 2020, 01:22:10 am »
LT3080
thank you AMYK
