Author Topic: What does "canned fix" mean?  (Read 6038 times)
Offline ErikTheNorwegianTopic starter
  • Country: no
  • Asberger, aspi, HIGH function, nerd...
« on: August 08, 2013, 10:35:49 am »
What does the term "canned fix" mean?
Hope someone can help me here.. :-)
Erik
/Erik
Goooood karma is flowing..
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
Re: What does "canned fix" mean?
« Reply #1 on: August 08, 2013, 10:57:23 am »
It's usually a small tin with a ring pull which contains a quantity of cannabis.
Sometimes it's used as a term to describe a standard fix for something, maybe a software bug or a known cure for fixing that hardware fault that occurs on a particular model of something.
Offline Psi
« Reply #2 on: August 08, 2013, 11:53:49 am »
Sometimes it means a fix to a problem that simply involves buying something ready made off the shelf.
Reference to buying a can of food.
eg, "John keeps using the soldering iron when i need it, time for a canned fix, second iron ordered"
« Last Edit: August 08, 2013, 11:56:07 am by Psi »
  • Country: no
« Reply #3 on: August 08, 2013, 01:24:01 pm »
Thanks  !!
 Great help and thanks again!!
Good carma is sendt your way!!   ^-^
/Erik
Online Fraser
« Reply #4 on: August 08, 2013, 07:06:35 pm »
Often used in connection with power supply rebuild kits consisting of uprated components and capacitors. Very common in the Satellite receiver industry. No diagnostics needed, you just replace ALL the components that may be faulty. Fast and efficient for the customer but not as fulfilling for the keen tech. I always like to know what failed  ;)
Online westfw
« Reply #5 on: August 08, 2013, 08:42:51 pm »
I would expect a sort of all-inclusive repair for a particular (common) problem.  For example, those iPhone screen replacement kits that come with spudgers, suction cups, and the other "special" tools, plus instructions, needed to effect the repair, in addition to the screen itself.   Or the "ink jet refill" kits that include a syringe, drill,  and magic chip on a pcb in addition to ink.  Or a SW virus removal tool.
Specifically, analogous to the difficulty of preparing canned food, vs cooking "from scratch."
Offline NiHaoMike
    • Facebook Page
« Reply #6 on: August 09, 2013, 02:08:00 am »
In HVAC, it is a canned product (leak stop or whatever) that "fixes" the problem without really fixing it.
Offline MacAttak
« Reply #7 on: August 09, 2013, 07:47:40 am »
As I have heard the term used, it generally refers to a "prescribed fix" for a known problem that does not require additional troubleshooting or diagnosis effort. Someone else has solved the problem, and it occurs frequently enough that there is now a "standard" solution for it. The "canned fix" is the documented series of steps (possibly including replacement hardware parts) used to resolve that specific problem.
Offline free_electron
    • SiliconValleyGarage
« Reply #8 on: August 09, 2013, 02:33:48 pm »
Yep, canned fix. For problem xyz : replace all these parts , or replace this board. Done. These are repair instructions for frequent problems where someone made a kit woth instructions what to do. No need to think. Simply follow the instructions and it will work. Most of these things are more economical (even though you may be replacing non defective parts in the process) as you save the time required for troubleshooting it at component level.
Offline nitro2k01
« Reply #9 on: August 09, 2013, 06:25:52 pm »
Ha. Are you just making that up as a joke, or is it a thing?
Offline c4757p
  • adieu
« Reply #10 on: August 09, 2013, 06:34:01 pm »
Sure! Around here, the canned fix of choice, rather than cannabis, is methamphetamine, which you can pick up at your friendly neighborhood Walmart1.
1From the customers, not the shelves.
Offline smashedProton
« Reply #11 on: August 09, 2013, 06:39:37 pm »
Haha I saw a video of how to make it out of curiosity one time.  They use sulphuric acid litium from batteries and ether...  why anyone thinks that it is remotely a good idea is beyond me.
http://www.garrettbaldwin.com/
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
Offline c4757p
  • adieu
« Reply #12 on: August 09, 2013, 07:00:23 pm »
Because stupid.
For just about every drug out there I can name at least one person I know who's done it and is otherwise a reasonably intelligent person. Meth? Not a chance. I live in an area with a big meth problem, so finding meth-heads isn't hard, too. Not a single one of them was ever intelligent once. You're lucky if you can find one who can spell his name.
Offline Stonent
« Reply #13 on: August 09, 2013, 09:43:47 pm »
Actually you can get pretty close sold at walmart:
http://en.wikipedia.org/wiki/Lisdexamfetamine
http://en.wikipedia.org/wiki/Methylphenidate
http://en.wikipedia.org/wiki/Dexedrine
http://en.wikipedia.org/wiki/Adderall
Offline c4757p
  • adieu
« Reply #14 on: August 09, 2013, 09:59:23 pm »
Yeah, but those don't have the delicious battery acid. That's the best part!
  • Country: no
« Reply #15 on: August 09, 2013, 10:26:42 pm »
About time to say that answer is deliverd and go on with a new question.... 8)
Time to close the tread..
/Erik
Offline c4757p
  • adieu
« Reply #16 on: August 09, 2013, 10:38:28 pm »
Sorry! :-[
  • Country: no
« Reply #17 on: August 09, 2013, 10:49:11 pm »
Sorry! :-[
No problem, it just became pretty OT...  ;)
Im sorry that you got those problems over there. Last time i was in Phily, i was shocked how  bad the town had become. Very much poor people, and very much drug abuse. So sad.
/Erik
Offline c4757p
  • adieu
« Reply #18 on: August 09, 2013, 10:54:01 pm »
We're not Philly bad..... yet. Just a small, sad, former manufacturing town nestled between two highways with major drug routes.
I'll try to stop derailing threads so much.... :-DD
