Author Topic: any good way to emulate fast NOR SPI/QPI /etc FLASH with SRAM ?  (Read 277 times)
Offline Hella_Wini22Topic starter
« on: September 26, 2024, 06:53:48 pm »
I'd like to play around with hardware that eitzher gets configured with ( FPGAs, FPGA SoCs etc) and/or execute code from such device (some microcontrollers, PC, CPUs etc).
To do this I'd like to use SRAM. Up to some extent, I could use onboard SRAM on FPGA, but those are quite small.
External DRAM is too slow latency-wise etc. Is there an obvious solution to this dilemma ? 🙄
Offline Benta
Re: any good way to emulate fast NOR SPI/QPI /etc FLASH with SRAM ?
« Reply #1 on: September 26, 2024, 09:05:56 pm »
Serial SRAM?
But you'll have to devise some kind of battery power to keep them active after programming.
Or do in-circuit programming with power on.
https://www.issi.com/US/product-serial-sram-and-serial-ram.shtml
Online tom66
« Reply #2 on: September 26, 2024, 09:22:14 pm »
I'm pretty sure you could emulate SPI ROM with another FPGA - with the bitstream stored in some external SRAM.  If you stick to SDR speed SPI flash (maybe 1-bit @ ~50MHz) then it would probably be a few hundred lines of Verilog to write a simple emulator.
Some fast microcontrollers with DMA might just about be able to do this as well.
As for an actual product, I'm not aware of one.
