Are they electronics grade, or metallurgical grade? That will determine what you can do with them, though if they are quite conductive they probably are metallurgical grade, used to refine steel. You probably can look to see if you can make some point contact transistors, or make a few diodes, or even a Schottky rectifier if you use some gold as a contact on the one face.
