There are four of these SO-8 chips (in parallel?) at the power-input of an old board. Looks like they are after an LM311N that maybe compares external DC-voltage to an on-board battery-voltage and selects between the two sources. So these would be FETs that switch between the power-sources?
As can be seen from the image, one was not very happy about a reverse-polarity incident...
"9430" at the top. "W829" at the bottom. Not 100% sure what it says in the middle. Googling didn't show anything at least quickly...
thanks!
