Effectively, but not by intention. If the hole in the male part is punched, whether or not it releases may also depend on which way up you insert it as a little bevel on the hole edge will probably permit it to release.
If you need a reliably releasable locking spade connector you need the sort with a spring tongue in the female part carrying the locking pip, that you can press to release.
