Author Topic: Weird squiggle on 20x4 LCD  (Read 1463 times)
Offline greencardiganTopic starter
« on: September 16, 2023, 07:43:41 am »
Anyone know what would have caused this weird squiggle on my LCD?
It wasn't there a few weeks ago when I last used my roaster controller.
Offline DavidAlfa
Re: Weird squiggle on 20x4 LCD
« Reply #1 on: September 16, 2023, 08:02:56 am »
No idea. Seems like damage to the polaryzer film.
Perhabs some solvent dropped on it?
Maybe made by realtek, slowly showing up,
In any case it needs a new LCD, thankfully inexpensive.
You have some with cool colours here:
https://a.aliexpress.com/_EwZ5zBv
« Last Edit: September 16, 2023, 08:05:36 am by DavidAlfa »
« Reply #2 on: September 16, 2023, 08:35:27 am »
The polariser is made with iodine crystals in a polyvinyl alcohol film. Heat, and damp, can both cause degradation. A slight contamination during the manufacturing process can probably act as a nucleation point.
The film can be replaced, but it's a fiddly job.
Offline jpanhalt
« Reply #3 on: September 16, 2023, 08:55:04 am »
Something similar is discussed here: https://www.eevblog.com/forum/beginners/why-i-do-not-like-fractals-on-my-lcd/msg4748645/#msg4748645
It obviously some defect.  Another possibility suggested in that thread is a fungus.
The following users thanked this post: amyk
« Reply #4 on: September 16, 2023, 10:05:19 am »
I'd be surprised if it's a biological vector, iodine is pretty good for sterilising things.
Offline jpanhalt
« Reply #5 on: September 16, 2023, 10:41:49 am »
I simply mentioned it as having been discussed here before.  Personally, I would lean more toward a crystallization artifact perhaps from decomposition of the PVA.  As for fungi actually growing in iodine, I agree that iodine is/was widely used as an antiseptic, particularly its complex with PVA.  However, a fungus growing between layers would not be exposed to it.
Bottom line: There is no definitive answer and those bothered by it, so far as I can tell, have not investigated it further.  Disassembly and microscopic examination to identify which layer is affected would seem to be a first step.  If it is in the polarizer, there are simple things that could be done to help pin its cause down.
« Reply #6 on: September 19, 2023, 01:00:46 pm »
Thanks. That does look like the same sort of thing.
I'll have to keep an eye on it and see how quickly it's 'growing'.
Offline eutectique
« Reply #7 on: September 19, 2023, 03:39:03 pm »
Resembles the tooth marks of a gastropod
« Reply #8 on: August 07, 2024, 06:22:34 am »
Just for the record. It's still growing slowly.
Offline tom66
« Reply #9 on: August 07, 2024, 07:58:32 am »
I have a TI-84 Plus that has the same kind of defect, but it is black pixels that are 'growing'.
Offline Psi
« Reply #10 on: August 07, 2024, 08:01:24 am »
Yep, looks biological to me.
Probably had some bacteria trapped inside during assembly and it just so happened to have enough food and light to grow for a short time.
If you mask it and hit only one side with some bright UV you might be able to prove it's bacteria if only the other side continues to grow.
Offline H.O
« Reply #11 on: August 07, 2024, 12:11:44 pm »
My fx-9750G has the same sort of thing. Always there no matter if the calculator is on or off.
It came that way when I bought it second hand a while back, I have not (yet) noticed it growing but now I'll keep a close look it just out of curiosity.
Offline Buriedcode
« Reply #12 on: August 07, 2024, 07:12:27 pm »
I have several displays with these - all of which are old, 20yrs+.  I just assumed it was a delamination of some kind.
Offline SiliconWizard
« Reply #13 on: August 08, 2024, 12:17:58 am »
Looks like a pretty standard 20x4 LCD which you shouldn't have any trouble replacing.
« Reply #14 on: August 08, 2024, 01:06:14 pm »
It's not bacteria. Here's a picture of a (simulation of) fractal percolation growth in porous glass and microemulsions:
A brief excerpt:
In any case, many bacteria are resistant or immune to UV: https://www.nature.com/articles/s41598-023-40996-8
Offline jpanhalt
« Reply #15 on: August 08, 2024, 05:44:47 pm »
In any case, many bacteria are resistant or immune to UV: https://www.nature.com/articles/s41598-023-40996-8[/color][/font][/b]
The paper cited in your link seems to say the opposite.  Your link says:
There is currently no evidence that pathogen resistances or tolerance can be induced following to UV-C irradiation.
Reference 9 is cited for that statement.  It reads:
Choi, H. et al. Can multidrug-resistant organisms become resistant to ultraviolet (UV) light following serial exposures? Characterization of post-UV genomic changes using whole-genome sequencing. Infect. Control Hosp. Epidemiol. 43, 72–78 (2022).
Of course, some microorganisms are more susceptible than others to UV.  Simply shining a UV light on something doesn't mean that something is actually exposed to the UV.  Absorption by intermediate materials (window glass in some cases or cornified epithelium as in the Nature paper) can protect underlying things/tissues from being affected.
« Reply #16 on: Yesterday at 10:09:57 am »
You clearly haven't understood what they wrote at all.
"There is currently no evidence that pathogen resistances or tolerance can be induced following to UV-C irradiation" means that non-resistant strains do not become resistant by being exposed to UV-C, in lab conditions. It says nothing whatsoever about extant resistant strains, but implies that UV resistance may be a complex mutation that doesn't happen easily.
This is a good thing in context, as it means UV sterilisation in labs/hospitals etc is unlikely to pose a risk in regards to resistance mutation.
As to the second point, that UV is easily blocked and therefore using it in this case may be ineffective, that only reinforces my point that exposing these displays to UV in an effort to "sterilise" them is unlikely to be useful, even if the problem is a bacterial one and not one of fractal percolation of dielectric relaxation.
