That's great, thank you!
May I kindly ask if we can have a preview that renders math formulas (at preview time, before pressing Post). Right now the preview does not render the graphic form for math formulas. I can see the drawn equations only after pressing Post, which is cumbersome when there is more complicated formulas to write.
Example:
Write a line of text with the inline formula \$ a = b + c \$, or a formula in display mode (aka single line centered formula)\[ x = y + z \] The formulas will only appear rendered in their graphical form only after posting the message, but not at preview.
This is not a critical bug, but rather a nice to have, and only if it doesn't mess anything else.
For now (if that helps debugging) I've found a workaround:
- press Reply to get to the edit post page
- save the Reply page on disk (from the web browser, mine is Firefox ESR)
- click to open in another browser tab the saved page from the local disk
- edit the reply text and the formula in the tab that was opened from the local disk
- press Preview in the tab opened from the local disk, this will show a "live" preview coming from EEVblog, a preview with the formulas rendered
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
- at another press of the preview (from the "live" page), the formulas will not be rendered
- now, if I want to make further edits, I press "back" in the browser, so to arrive again at the reply page that was opened from local disk, edit and press preview again, that will open again a preview coming from the EEVblog (including rendered formulas) and so on
- once the reply text and all formulas are OK in the reply tab that was opened from the local disk, press "Post".
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
