Author Topic: Watch Timing Machine  (Read 14928 times)
Online xrunnerTopic starter
  • hp>Agilent>Keysight>???
« on: March 29, 2015, 02:36:55 am »
Well I had no idea ...
Was just surfing Ebay for something new and found this thing. I had no idea they made such a thing. I'm thinking - gosh there must be another good use for that thing, I mean I have no watches that it would be able to calibrate. Doesn't it listen to the "tick - tick - tick"? And with the watch plastered to the holder like that, how would you adjust it?
Kinda expensive too.
Thoughts?
http://www.ebay.com/itm/Multifunction-Timegrapher-NO-1000-Watch-Timing-Machine-Calibration-Tools-/191543026447?pt=LH_DefaultDomain_0&hash=item2c98daa30f
Online SeanB
Re: Watch Timing Machine
« Reply #1 on: March 29, 2015, 05:14:47 am »
Yes, it picks up the ticking of the balance wheel, and you adjust it by seeing the error, then opening the back and adjusting the spring control, then put it back and measure again, until it shows the error is under 1 second a week or so. An iterative process, but it works well. Others use a light source and a photocell to detect the movement of the balance wheel or the escapement inside the watch to get the information.
Offline Rerouter
« Reply #2 on: March 29, 2015, 05:22:06 am »
I have in the past use a piezo buzzer as a vibration pickup for my frequency counter, have it taped to the side metal while i adjust at the back of automotive mechanical clocks, means you can trim one in in 40 seconds as opposed to 2 days,
where as most of these ones tend to be based on high gain microphones, you can still get away with a piezo if you have a lot of gain,
Offline amyk
« Reply #3 on: March 29, 2015, 05:41:55 am »
Isn't it a little ironic to adjust mechanical watches using a machine based on a quartz oscillator?
Offline rollatorwieltje
  • I brick your boards.
« Reply #4 on: March 29, 2015, 09:40:16 am »
1 second a week would be extremely good for a mechanical watch, the "high end" COSC certified ones are only -4/+6 seconds per day (measured over 5 positions and 3 different temperatures).
I can regulate my low end Seiko automatic by placing it face up or face down. Face up it runs a little slow, face down it speeds up... This is quite typical behavior of mechanical watches.
If you want a practical and accurate watch, get a 10$ Casio. It will be orders of magnitude better than even the most expensive swiss mechanical movements assembled by nude virgins under moonlight. Mechanical watches are terrible timekeepers.
Online SeanB
« Reply #5 on: March 29, 2015, 09:51:52 am »
Time to replace the little 377 coin cell in my cheap $5 watch. It stopped 15 seconds to midnight........
Offline G7PSK
  • It is hot until proved not.
« Reply #6 on: March 29, 2015, 10:38:46 am »
In the 70's I worked for a watchmaker,he used a similar device that picked up the ticking of the watch but as the display was a printed paper roll to save paper he would just turn on the speaker of the device and listen to the ticks, he would then adjust the watch accordingly, within a minute or so he had the watch adjusted to a second or two a week. And he did not have a beard or a tongue sticking out while making the adjustments, a poke with the tweezers and it was done.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #7 on: March 29, 2015, 11:00:50 am »
Thoughts?
£184 seems very reasonable for a specialist piece of kit like this.
I wouldn't be surprised if they were $1k+ before the Chinese got into the game
Day Job: Mostly LEDs
Offline sdg
« Reply #8 on: March 29, 2015, 01:40:44 pm »
 -sdg
Online Alex Eisenhut
  • Place text here.
« Reply #9 on: March 29, 2015, 03:09:58 pm »
Things like this have been around for a while. Here's a nice little gem of a show I like a lot
you can see one in action.
Offline G7PSK
« Reply #10 on: March 29, 2015, 03:13:40 pm »
Good watch makers tools are expensive, those so called cheap watchmakers screwdrivers found on e bay and in the pound/Dollar shops don't work out cheap the bend and break or the handles tun on the blades or they slip and damage the watch as in electronics good equipment costs but pays for itself in the end.
Offline amyk
« Reply #11 on: March 29, 2015, 03:49:02 pm »
5 seconds a day is around 58ppm, while a typical quartz watch is in the single-digit ppm range, so it's around an order of magnitude better at most.
See http://tf.nist.gov/general/pdf/2276.pdf
This one actually appears to be a clone of another Chinese one, the "TYMC MTG-1000", which costs roughly twice as much.
...and a PC containing a suitable microphone will work, using this software: http://tokeiyade.michikusa.jp/download.html
Offline Zero999
  • 0999
« Reply #12 on: March 29, 2015, 04:26:28 pm »
Less people wear watches now than they used to as they've been replaced by phones.
« Reply #13 on: March 29, 2015, 05:06:45 pm »
My watch has has a very common 7s26 movement, it's specified at -20/+40 seconds per day. That's about 300ppm.
There's also an Android app to perform these measurements, WildSpectra. It depends a bit on the watch and the microphone in your device if it works though, my watch is too quiet.
Pretty much only watch enthusiasts wear mechanical watches, I doubt they will switch to a smartphone. The vast majority wears (wore?) a quartz watch, this machine is useless for those watches anyway.
Offline dannyf
« Reply #14 on: March 29, 2015, 09:09:51 pm »
Thoughts?
I bet you that you can do it with a smart phone app: it has a microphone, with adjustable gain (20-30db typically) and a graphics display + canned user interface.
Otherwise, it is not that hard to make your own.
Offline Howardlong
« Reply #15 on: March 29, 2015, 09:23:41 pm »
Thoughts?
So you've made one then?
Offline dannyf
« Reply #16 on: March 29, 2015, 09:37:01 pm »
If I make one, what will you do in return?
Offline icon
« Reply #17 on: March 29, 2015, 11:02:12 pm »
Thoughts?
Here's a look at the innards of a similar one, plus some info on how they work.
https://www.eevblog.com/forum/reviews/weishi-mtg-3000-%27multi-function-timegrapher%27/
HTH
John
« Reply #18 on: March 29, 2015, 11:16:04 pm »
Thanks really nice explanation. Yea they misspelled the description. I bet the manual they include is equally as bad.
Offline dannyf
« Reply #19 on: March 29, 2015, 11:29:31 pm »
From a modern mcu perspective, those things are quite simple in term of basic functionality: you use a microphone to listen to the beats. With that, you time a known pulse train. Count until a certain number of beats have passed and you read your timer counter. Done.
Offline Howardlong
« Reply #20 on: March 29, 2015, 11:40:22 pm »
So I take it that's a "No" then!
Offline SteveyG
  • Soldering Equipment Guru
« Reply #21 on: March 30, 2015, 07:20:16 am »
The one in the Secret Life of Machines video linked earlier works with a quartz digital watch.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline sdg
« Reply #22 on: March 30, 2015, 08:21:54 am »
[ The vast majority wears (wore?) a quartz watch, this machine is useless for those watches anyway.
Really ?
This Seiko Caliber 7545A says otherwise.
 -sdg
« Reply #23 on: March 30, 2015, 10:46:00 am »
Really ?
No point in adjusting a quartz with another quartz, you'll need something significantly better. Your measurement instrument must be at least an order of magnitude better than the device under test. Also the device posted measures amplitude and beat error of the balance wheel, both are useless for quartz.
Offline sdg
« Reply #24 on: March 30, 2015, 11:06:24 am »
My misunderstanding : I thought you were saying that quartz watches cannot be adjusted. The "not with this device" got lost in the translation...
 -sdg
