I like that idea, but I have no idea how to realize that with just a spare comparator (if it is spare, see below). I would need a VCO, that comparator to digitize the LC tank phase, an XOR gate, and some passives to realize that. That would add a lot complexity/cost. Currently the [almost] solution is ~ 10x10mm without coil, and <3Euros.
Well, 4046s are at least a third of the footprint, and a tenth of the cost...
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
When thinking of an uncontrolled free-running RC oscillator, that will not work. Q is 80 in the circuit, so bandwidth is only 2kHz or 1.2%. Plus, the available change in amplitude from detecting metal is only ~ 10%, so I cannot allow for much detuning. I only observed marginal detuning effect at the chosen operating frequency, it is optimized for best eddy current sensitivity.
So you're saying it's too sensitive? Put more resistance on it!
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
It was not there in the first design, but I experienced that I could not allow for the temperature dependency of a real diode.
Ahh. Well, with a Q over 10, you can get plenty of voltage on the node (>50V!). If you use a 74HC4046, the logic pin output resistance is around 50 ohms. For L and C in series, 10mH and 100pF gives Fo = 159kHz and Zo = 10kohms. With an ESR of 50 ohms, Q max is 200, not bad at all! (If you measured Q = 80, then I'm guessing the inductor has 125 ohms ESR. Unclear if that was including the comparator and sense resistor.)
With a PLL tracking resonance, you'll have all the signal in the world (up to 250V, apparently!), no worries on diode offsets.
The diodes are actually a rather difficult part, because to retain the same Q factor, the load needs to be over 1Mohm. That's pretty high for a diode; and, needless to say, you can't use anything near that (i.e., at least 4Meg) for the voltage sense divider.
But also with so much signal, I doubt a PLL is really necessary. It should be no trouble getting that to start, with any kind of oscillator design. Going back to your original circuit: make sure it is astable, not bistable. Change the negative feedback divider so it hunts around Vdd/2, and, maybe cap-couple (with just a few pF) the high voltage signal to the +in?
