Author Topic: "Veritasium" (YT) - "The Big Misconception About Electricity" ?  (Read 248078 times)
0 Members and 30 Guests are viewing this topic.
Offline adx
Re: "Veritasium" (YT) - "The Big Misconception About Electricity" ?
« Reply #1025 on: January 22, 2022, 01:55:54 am »
Let's take a step back, maybe I'm missing the point completely.
Are the fields that carry the energy outside the conductors normal electric and magnetic fields that we can measure if we want to?
Yes.  The 'S-field' vector at any point is the cross product of the E and H field vectors at that point.
Except for this:
https://en.wikipedia.org/wiki/Aharonov–Bohm_effect
 :o
Offline adx
« Reply #1026 on: January 22, 2022, 05:03:08 am »
So you are saying the thinner we make the insulator, the stronger the magnetic and electric fields will become (to carry the same amount of energy as before)?
The stronger the electric field becomes, the voltage difference is the same, it is where the energy comes from (the potential energy).
The magnetic field does not change, except for where it is cancelled by current flowing the other way in the shield. For example in your shielding box, if it were made of copper, the magnetic field wouldn't be altered by its presence or size of holes.
Offline adx
« Reply #1027 on: January 22, 2022, 12:10:29 pm »
I was thinking of something yesterday, long those lines. Said before but might be worth repeating in clearer form as a kind of alternate 'Poynting equivalence describer'.
Sredni's "orange parallel resistors circuit" (source: https://www2.oberlin.edu/physics/dstyer/CircuitSurveyor/help.html):
It is infinitely deep, so magnetic field in each loop is the same everywhere and zero outside the circuit. Thus it exactly represents the current flowing in each loop per KCL (completely independent of shape).
Voltage simply divides across the 'gaps', evenly if considering parallel wires (which are plates in this example), so increasing their spacing reduces the calculated electric field. The electric field exactly represents the voltage between the wires divided out over space.
Circuit theory requires that power is calculated from the voltage between wires, so considering power to be spread between the wires as a density is as reasonable as anything else. Therefore multiplying the magnetic and electric fields doesn't just give the same result as circuit theory, but is directly equivalent.
For 3D, consider replacing the front and back of the circuit with empty space, so it ends up as a slice say with square wires. Then consider the "vacuum contribution" to power flow - it should be zero. The fields spill around the wires because it is a 2D circuit in 3D land. The resulting mess is from adding vacuum and the complex topology, not because of any fundamental change to the way the circuit or its fields operate. (This last paragraph a slightly circular argument because we already know it works, but its purpose is to guide intuition, not prove anything.)
This isn't what I was getting at over the past couple of pages, but might be a useful stopgap.
Offline SilverSolder
« Reply #1028 on: January 22, 2022, 01:00:12 pm »
Do electrons still actually flow in the wires, under the influence of the fields?
Offline adx
« Reply #1029 on: January 22, 2022, 02:47:14 pm »
Yep. I think the argument (whatever it is) is over what they carry, being little springs with long range and peculiar behaviors. More spring force = more energy (even if the spring never moves and only contributes to the stationary mass of an object). Voltage is that force for electrons, so the arguments over where the energy is might go on forever.
Offline Naej
« Reply #1030 on: January 22, 2022, 08:04:17 pm »
With a Faraday cage, you removed (almost entirely) the capacitive coupling between the wire near the switch and the light bulb.
You also added a strong capacitive coupling between the wire and the cage (because the distance is tiny), and the cage is a transmission line.
So you'll get large reflections at entry/exit of the cage, which will die down after a millisecond, and the lamp will be in its normal DC state.
In the light point of view, your cage is made with double-faced mirrors with 2 tiny holes, and you suddenly switch a light on. After a millisecond, there will be as much light inside as outside.
(And of course, no need for Poynting's vector to explain anything)
« Reply #1031 on: January 22, 2022, 08:33:14 pm »
Yeah, I had misunderstood the argument - thought there was something new in it :D
Offline bsfeechannel
« Reply #1032 on: January 23, 2022, 07:35:37 pm »
Except for this:
 :o
I find it amusing that we resort to quantum mechanics, which is much more complicated and less intuitive than classical electrodynamics, when we struggle with the latter exactly because it is unintuitive and complicated.
Anyway, the Aharonov-Bohm effect shows even more strikingly how the action is in the fields. Of course, Feynman has a chapter dedicated to the subject.
What we mean here by a “real” field is this: a real field is a mathematical function we use for avoiding the idea of action at a distance. If we have a charged particle at the position P, it is affected by other charges located at some distance from P. One way to describe the interaction is to say that the other charges make some “condition”—whatever it may be—in the environment at P. If we know that condition, which we describe by giving the electric and magnetic fields, then we can determine completely the behavior of the particle—with no further reference to how those conditions came about.
The technical term for "avoiding the idea of action at a distance" is called locality. There's no telekinesis in physics, apparently.
Space is not an empty volume in front of you. It is an active player that provides the proper interaction between objects.
I like it at the end where Feynman shows where classical and quantum ED converge, i.e. give the same result, for when the "solenoid" is not microscopic, as it is in the Aharonov-Bohm experiment.
Offline adx
« Reply #1033 on: January 24, 2022, 03:23:42 am »
I don't really follow your arguments from a logical sense, but I (think I) know what you mean so am happy to leave it there or even 'agree to a degree' (just made that up).
Best I can understand is that you seem to be saying / proposing / hypothesising / believing that a field is a real fundamental object in its own right, that exists independently of the particles that some say carry, produce or otherwise 'have' the field. They act through the field, or at least are composed of something like energy in the field (so in that sense the particles are subordinate to the field and do not carry field around). Kind of like an uberaether. My position is "I don't know".
But what I will say is that I never understood what the hoopla about "action at a distance" was and is. Say I'm 4 and pick up some magnets and play with them, I'll soon come to a conclusion that there is some invisible force acting between them. Then I'm 14 and playing with a vacuum chamber I made from a peanut butter jar and old fridge compressor (to make plasmas with EHT straight off the top of an EL509). I wonder if magnets act the same in there, so rig up a test (not something I've actually ever seen reason to do). Force does not change. My conclusion is "it goes through the vacuum". Later (much), the neighbour's cat comes visiting while I am flying a remote control helicopter, looks at my hands and the thing flying round and decides that it is not terrifying or edible because I seem to be controlling it somehow. It's as if I've got a string, or stick, but it's invisible, and that's no big thing because he is used to pretending the string or stick doesn't exist. Given the experimental capabilities of humans and philosophical prowess of cats, what more is there to know than "can't see it so don't know what it is"? Do we really want cats experimenting and humans philosophising over what it is?
Edit: Ok EHT not off that and probably not even an EL509, a shame the number of B&W TVs I destroyed.
« Last Edit: January 24, 2022, 06:28:56 am by adx »
Offline adx
« Reply #1034 on: January 24, 2022, 03:49:57 am »
Ang on, didn't read that properly. The Aharonov-Bohm experiment is the size of a desk, if I have that picture right. I just very briefly looked at an explanation on Quora where it is compared to a (toridial) transformer - the windings are in a region of zero magnetic flux, yet they still pick up a voltage because of the enclosed flux. A "turn" is potential, I guess.
Offline adx
« Reply #1035 on: January 24, 2022, 02:06:52 pm »
I had planned to extend this drawing for another post but this is topical now - on the existence of fields.
It refers to a concept I posted before, but the diagram might make it more obvious.
Take a vacuum (not mine!), it contains the entire universe, possibly a very small one, but enough space to know there is no charge.
Is there a field? Radio waves could theoretically travel if it's like ours, but there is no charge, so we'll never know. It would be a strange world (or universe) where there exists a facility for something which can never occur or even be guessed at - a philosophical uphill battle getting that to make sense. That would include space and time of course, but how confident could you be of a functioning EM infrastructure in such a place? If it is like ours, is there anything yet to be discovered in ours that could affect what is theoretically possible or impossible there?
1 electron: Is there a field? There is nothing else to interact with directly. Perhaps its radiation resistance could be measured, and the mass of distant space measured somehow to check where the energy went.
2 electrons: Is there a field? Static forces exist, and can be measured. It's like my magnets example above. You'd know there is a force, but any concept of a field would have to be pretty limited, or unnecessary, until you discovered radio. Then it might be pretty tough to test what is going on to form an opinion over how it works.
3, 4 electrons: Now you can start testing things more completely. Things like how it behaves in 3D.
Offline Sredni
  • Country: aq
« Reply #1036 on: January 25, 2022, 11:38:48 am »
To my knowledge, the AB effect is a quantum effect that manifest itself on a microscopic scale (as bsfeechannel pointed out a few posts back). Very loosely speaking, it can be thought as being the consequence of the 'smearedness' of the wave function of the electrons: even if the little hard sphere we represent in our mind as being an electron is in a region without B, its wave function is spread out to encompass the microscopic solenoid and the region where B is.
It happens to be as magic as the interference of an electron with itself in the the double slit experiment. If we think the electron as a little hard sphere, then the double slit experiment with single electrons can only be explained by black magic. It appears that the little ball is capable of 'sensing' the presence of the slit it does not go through. But when you consider wave functions, that are delocalized, it seems a little less strange (while still remaining strange, but that is because we are limited to think in terms of either waves or particles).
The AB effect, an electron being able to sense the static magnetic field 'hidden' inside the solenoid, can thus be compared to the ability of an electron to sense the slit it did not pass through.
Trying to transpose this behavior to the macroscopic world is, in my view, trying to say that John, who entered the room through the front door, has also entered the room through the window. Or that, since in the quantum realm there is a tunnel effect, there is an appreciable probability that John has walked through walls. No, that probability is appreciable only if John is the size of an atomic particle and the walls are nanowide.
(A final note: in the case of the toroid in the macro world, we are able to 'detect' the B field hidden inside the infinite solenoid because it is changing and therefore the dA/dt brings into existence an actual electric field Eind in the point P outside the solenoid. Locality is saved. The AB effect is about a constant B field, so dA/dt is zero and there only is a time-constant A around the solenoid)
« Last Edit: January 25, 2022, 11:57:05 am by Sredni »
The following users thanked this post: bdunham7
Offline adx
« Reply #1037 on: January 25, 2022, 01:14:29 pm »
... we know energy is propagating.  We can measure it and we can calculate it.  We know the wave fronts are moving and we know that since there is energy in the ...
(emphasis mine)
That's a bit I had trouble with. We can't really, because it changes its direction.
Offline adx
« Reply #1038 on: January 25, 2022, 02:31:05 pm »
So yes, you can transfer energy from one wire to another at DC steady state and it happens all the time.
Can you show us? =)
The field effect does not reduce with distance, that is an illusion caused by objects appearing smaller as they go further away in space(time), so there is no limit to the spacing.
That's quite fascinating. Can you show us?
Finally, to answer these. For completeness, said I would.
Point 2: This is simply that the total flux (the "field effect") remains the same out to infinity. I had thought of adding that to my diagram above, but it doesn't work exactly for discrete charges like electrons. It is a bit tongue in cheek, but highlights that things seeming to get smaller as they get further away is an illusion, a property of space, not the things. And why scenes don't reduce brightness with distance. In the field view, the field is still there 'in full force' (it just spreads out). Indeed plane waves don't reduce in intensity, walls of charge don't either. But in the particle interaction view, there is this 1/r^2 effect and no need for the double entry accounting type of approach of defining an intermediate field.
Point 1: Energy transfers from one wire to another at DC steady state and it happens all the time:
I suppose time-varying electric fields will be produced by flowing charge. If you consider that a circuit must have a return path, then an electron going forward will push on the electron coming back, taking work from it and putting it into the field, which is returned after it passes. I guess topped up by the relativistic effect which produces magnetism, but that will be unequal and store energy in the electric field while current flows. Maybe something like that is responsible for the Poynting vector behaving as it does here.
Offline bdunham7
« Reply #1039 on: January 25, 2022, 03:20:46 pm »
Offline Naej
« Reply #1040 on: January 25, 2022, 06:09:09 pm »
Absolutely not. Even if the solenoid is inside an impenetrable barrier (the electron wavefunction is 0 in this position) , you still get the effect.
What it shows is that the potential momentum A is actually a thing: the electron detects a changing A along its 'path'.
Offline rfeecs
« Reply #1041 on: January 26, 2022, 06:25:11 pm »
A couple more videos from Ben Watson:
Offline Naej
« Reply #1042 on: January 26, 2022, 08:18:46 pm »
Maybe there's a simple word for a build-up of surface charges on two opposing conductors separated by a dielectric?
Offline SiliconWizard
« Reply #1043 on: January 26, 2022, 10:08:39 pm »
Fields galore =)
Offline aetherist
  • The aether will return. It never left.
« Reply #1044 on: January 28, 2022, 01:29:33 am »
I re-did the ladder line tests I ran a few days ago to demonstrate the ~80ps delay over the 24mm wire spacing.
I used the same probe to probe the "switch" (the scope's integrated TDR, cyan reference trace) and the bulb side (green trace) so as not to introduce skew.
The cyan trace was taken at 10mV/div and the green at 2mV/div, so there's significant attenuation before we approach DC steady state.
The yellow trace is the TDR trace which you can't get rid of without turning off the TDR: the TDR triggers the scope and turns on a long time before the displayed traces, it has to propagate through the cables to the DUT, note the trace delay of ~27ns.
I measured the time between the beginning of the two rising edges, at about the 10% level.
(The scope's pretty dusty: I had a ceiling collapse some months ago in the room adjacent to this, and it's still being repaired, so things get pretty dusty round these parts.)
Nice. I have not seen any comments re your experiment.
I did not know that old scopes had 20 GHz -- how much did they cost new? -- how much nowadays secondhand?
It confirms that some kind of crosstalk (mainly radio i suppose) crosses (the 24 mm) at c m/s.
I would like to analyse your results, could u please advise....
1. The rise time of the pulse?
2. The fall time of the pulse?
3. The overall time of the pulse -- or the flat time (ie total time minus the rise & fall)?
4. Or was it a step pulse, ie with no fall?
Thanx.
« Last Edit: January 28, 2022, 01:31:49 am by aetherist »
Offline aetherist
« Reply #1045 on: February 01, 2022, 09:48:22 pm »
Howardlong messaged me the following info.
Rise time 10-90% at the scope is 36 ps. By the time it gets to the feedpoint, it'll be about 45 ps due to dispersion in the coaxial feed.
Fall time looks similar visually but I didn't take a measurement. Pulse width is 608 ps.
Howardlong has already mentioned that his signal crosses (first reaches) to the opposite wire in  80 ps which he says accords with the speed of light for the  24 mm distance tween the pair of wires in his  450 Ohm antenna ladder line. Howardlong in effect says that this supports Veritasium's expectation that Veritasium's bulb can possibly light (start to light) in 1/c seconds (ie 3.3 ns for Veritasium's 1000 mm spacing).
These kinds of transients have at least say 4 stages.
I wanted to have a closer look at Howardlong's experiments to look at the first stage, stage-1 of his transient. But i will come back to that another day.
Today i will jump ahead & look at stage-2 of his transient.
Howardlong X using 4 ft of ladder antenna line (wires 24 mm apart). He got 12 mV, with 58 mV in the other wire, which is 20.7% (20 GHz scope).
Schantz X using 100 ft of 300 ohm twin lead antenna line (wires 7 mm apart). He got 60 mV, with 340 mV in the other wire, which is 17.6% (100 MHz scope).
AlphaPhoenix X using 1000ft of 24AWG  enameled copper wire (wires 250 mm apart). He got 0.2 V, which climbed to 1.7 V, which is 11.8%(100 MHz scope). Actually his source is 5.0 V, so 0.2 V is 4.0%.
Silicon Soup (youtube) does a Finite-Difference Time-Domain simulation (1000 mm), gets a 0.3 mA signal from a 1.47 mA current, which is 2.0% 20.4%, for a mini-version of the Veritasium circuit. I don’t know how his pseudo-signal happens (its something to do with Maxwell)(displacement current perhaps).
All of the above percentages are astonishingly high. But i think i know what happens.
A step signal (voltage)(current)(Heaviside might say energy current)(Dollard might say impulse current)(whatever) propagates say to the right along the right half of our circuit, along the say bottom wire.
The bottom wire in that half is gradually flooded with negative charge, starting at the source (at the midpoint of the circuit), the flooding progressing to the right towards the short at the end.
The growing negative charge on the surface of the bottom wire gradually repels more & more free surface electrons (conduction electrons) on (along) the top wire, some go right (to the end), & some go left (to our bulb).
The electrons pushed right (along the top wire) tend to bunch up, because they are flowing in the same direction as the propagating step (in the bottom wire).
Actually, the free surface electrons in the top wire flow much more slowly (say c/100,000)(in the plastic insulation) than the step (2c/3)(in plastic), hence they are overtaken & left behind.
But, their wavefront propagates much faster (along the top wire) than c/100,000, perhaps c/100, perhaps c/10  (still thinking). Anyhow, the wavefront (along the top wire) too is overtaken.
The result is that say 50% of the escaping electrons in the top wire go left & 50% go right.
The electrons flowing left create a flow of electrons flowing left through our bulb, which manifests as a voltage drop across our bulb.
Our bulb turns on (weakly) a little after d/c seconds, ie as soon as (enough) electrons start to flow (leftwards) through the bulb on our top wire.
Our bulb glows brighter as the flow of electrons through the bulb increases.
After a short time the flow through our bulb reaches its initial maximum (say 10% of the current in the bottom wire).
[In the Veritasium gedanken (wire spacing d is 1000 mm) this would be a little after 1/c.]
Eventually the step (propagating right) in our circuit will get to the end of the bottom wire & will enter the top wire (via the short), & go to our bulb (while overtaking most of the electrons escaping to the left).
While the step is in the top wire it will push a much greater number of free surface electrons in the top wire towards our bulb, however this extra (temporary) current will lag the step (it might show as a hump on the scope).
When the main signal reaches our bulb the bulb will achieve full brightness, ie there will be a big sudden jump step in the voltage (followed by the aforementioned hump).
[In the Veritasium gedanken the main signal would reach his bulb in 1 second (his half circuit is 1 light second long).]
Regarding conduction electrons deep inside our top wire, these might drift left & right, in which case they would add to the current (at our bulb), but i reckon that any such drift would be insignificant.
However, conventional theory has it that this internal drift gives us 100% of what we call electricity.
I reckon that the induced drift in our top wire would add less than 1% to the initial current through our bulb.
Later, well after the main current first arrived, drift would account for nearnuff zero% of the current through our bulb.
And likewise surface electron flow would probably account for nearnuff zero%.
The electrons escaping to the left will give a current & voltage (signal) at the midpoint of our top wire (ie at our bulb). The size of the signal will depend on the wire spacing. The signal will begin to grow as soon as the E×H radiation reaches across, ie the delay is d (metres)/c (m/s), where d is the spacing, & c is the speed of light in the medium (usually air). More exactly, the delay will depend on the location of our switch, relative to our bulb.
[In the Veritasium gedanken this switch-to-bulb distance is approx the same as the spacing tween his wires anyhow.]
I doubt that a (simple conventional) LCRX lumped element transmission line model can predict transient current, using a simple LCRX paradigm, using simple speed of light.
Any such model needs smarter components.
And truer speeds (& truer flow of surface electrons).
However i have never had any hands-on experience with transmission lines, or TL models (or the application of electricity theory of any kind).
However the repulsion of the electrons from (along) our top wire is not unlike the action of lots of little capacitors tween the bottom wire & the top wire.
Perhaps someone could do a (simple conventional) transmission line model for Howardlong's experiment.
« Last Edit: February 05, 2022, 02:13:18 am by aetherist »
Offline adx
« Reply #1046 on: February 04, 2022, 02:08:14 pm »
A lot of "advanced" thinking there, most of which I think I follow, but to me at least some is as confusing as the academic textbook treatments (with their diagrams of imaginary field lines, surface charges, and equations presented as some kind of reality in their own right).
I know it's only a work in progress and won't suggest it needs to fit this bill, but what I yearn for is some kind of description of rational physical reality which ultimately ties in well to experimental and numerical experience.
... gets a 0.3 mA signal from a 1.47 mA current, which is 2.0%, ...
(original formatting)
20%?
To me and some others here, these results were astonishingly low. For a properly terminated transmission line (which the arms of this circuit can be) and differential drive (which is impossible for the arms because they are driven with a common mode voltage), the initial voltage and current should be 50% of the steady state.
I don't know what "free surface electrons" are, nor why they should flow at such extremely high speeds "in" the insulation (I assume you mean the interface between wire and plastic). c/1000000 is 300m/s, compared with a drift velocity of somewhere around say 0.00001m/s expected at ~~10mA in the wire. (That's about 10000000 times slower.) It doesn't sound like you mean a skin effect, where electrons go fastest in the outer portion of a wire.
One thing about a wavefront overtaking the 50% of electrons who go right, is that this wavefront travels at the speed of light, so not only does it overtake those electrons in this particular case, but there is nothing which can overtake it in any situation. In the simulations you can see the calculated spherical wavefront match the speed of the signal along the wires. The pushing force of the electrons is delayed by 1/c too, so by the time the force reaches the electrons in the top wire, the wavefront has already gone past that x position along the region of the bottom wire. The wavefront is one and the same thing as the pushing force. It's hard to think of it in those terms (that a force can propagate in such a visually defined way through 'nothing'), but if we accept that the speed of light is a thing, then no other result is possible - we are watching the fabric of time itself in action.
From this thread I have learned there is no more to electricity than this pushing force, and resultant movement of mobile charge carriers (in this case electron drift within the confines of wire). Pulling forces exist with positive charge carriers and also an absence of negative charges.
I don’t believe any of the humps and bumps in Howardlong's result are due to any sort of difference between electron movement and what is conventionally known (EM, capacitance, magnetism). To me it's mostly down to measurement (and generator) risetimes and non-idealities. For those features visible in the simulations, it's possible to probe the simulation for understanding.
I was wondering if this experiment (eg AlphaPhoenix's) had proved some effect which has remained undiscovered (or more likely unnoticed), but there is very little to suggest that there is anything other than something obvious and known going on.
Or rather it would be, if people generally understood how electricity works.
Someone working in the field (pun always intended) will gain a very good intuitive understanding of how electricity behaves, but can remain completely in the dark as to what it is. I think this is down to education of the subject being so physically abstract, to the point that the teachers themselves undoubtedly do not understand it. Concepts have not changed in 150-100 years, relying almost entirely on mathematical descriptions from some of the early greats in the field. I think their insights are sometimes forgotten next to their maths. Textbooks have formed a strong collection of opinions, trotting out the same received truths, but their focus is on how to best educate students, not to clarify the world's "description of rational physical reality" mentioned above. Somewhere along the way, the meaning has become lost.
Offline SandyCox
« Reply #1047 on: February 04, 2022, 02:33:12 pm »
 :-DD The flat-earth version of Electrodynamics.
« Last Edit: February 04, 2022, 02:58:39 pm by SandyCox »
Offline aetherist
« Reply #1048 on: February 04, 2022, 11:11:13 pm »
(original formatting) 20%?
Yes 20.4% -- thanx – fixed.
But 20.4% for 1000 mm spacing is mindblowing.  I thought that the 2.0% should have been more like 0.2%.
I am surprised that conventional lumped element models for TLs have not yet been proven to umpteen decimals. What happened?
I asked that someone do a TL model for Howardlong's X. Such a model would ideally predict/postdict each of the say 4 stages of the initial transients (of the induced currents)(before the main current arrives). And it could ideally predict/postdict the other say 10 stages of later transients (after the main current arrives)(transients caused by reflexions i suppose). However i suspect that such models were never designed to predict initial transients. I suspect that the models are okish for the later transients. Anyhow i am surprised that today there exist any problems with the application of TL models. Or, are they mainly for amusing skoolkids? ? ? ? ?
Look at all of the pseudo-mini-capacitors joining the top wire to the bottom wire (in TL models). They are drawn with a say 1 mm gap. For the Veritasium gedanken i reckon that they should have 1000 mm gaps. Look at the induced pseudo-current from the pseudo-mini-capacitors, i bet that it is all sent towards the pseudo-bulb, no, i reckon that a half should be sent away from the bulb.
Free (surface) electrons are my idea. They are conduction electrons that live on the outside of a wire. On a bare wire they might flow at say c/10,000 in air, & a bit faster than c/10,000 in vacuum -- & say c/100,000 (ie 3 km/s) in the (air in the porous) plastic insulation (ie the portion of the plastic touching the copper), which is 30,000,000,000,000 times faster than pseudo-electron-drift inside copper.
My flow of free electrons is not a skin effect, skin effect is inside the copper.  I am happy with a concept of electron drift inside copper, & electron drift close to the surface (skin effect). But i don’t think that such drifts are significant, & i don’t like the conventional idea that electric current is due to average drift or somesuch (hence i said pseudo-electron-drift).
And i don’t like the conventional idea that slowly drifting electrons can bump each other & make a wave that propagates along a wire at nearly the speed of light. Especially as the speed of em radiation in copper is (i think) 10 m/s.
I believe that electricity (& everything else) is a process of & in the aether. I don’t believe in Einsteinian stuff. But i doubt that that is important here. I mentioned charge propagating along the bottom wire, but i didn’t explain. My idea is that electricity is mainly due to electons propagating along the surface of a wire. Electons are photons that hug the wire, propagating at the speed of light, eg the speed of light in plastic if the wire is coated. Electons have a negative charge, which might be equal to an electron's charge (or it might be more)(or less).
Anyhow, i can explain my electon theory some other day, & anybody can follow my reasoning re the bottom wire if they simply assume that i am talking about charge propagating at the speed of light. Except that they would then of course be confused that my propagation along the bottom wire is at the speed of light c/1 whilst my flow of surface electrons along the top wire is at c/100,000. The difference in speed is because one is a kind of photon whilst the other is a kind of particle.
My electon theory has pushing, but it does not have pulling.
I hope to analyse the (interesting) stage-1 of his initial transient later this week. Yesterday i looked into stage-2.
I was wondering if this experiment (eg AlphaPhoenix's) had proved some effect which has remained undiscovered (or more likely unnoticed), but there is very little to suggest that there is anything other than something obvious and known going on. Or rather it would be, if people generally understood how electricity works.
Or, my new idea (that electricity in/on/along a wire is due only to two new causes), electons, & the flow of free (surface) electrons, might explain things better. We will see.
I had another look at AlphaPhoenix's youtube yesterday, & i noticed a few new interesting things which i will comment on in a day or two.
What do textbooks say about the speed of electricity being affected by plastic insulation?
What do the TL lumped element models say about it?
Notice that my electon theory has no such problem.
« Last Edit: February 04, 2022, 11:54:38 pm by aetherist »
Offline aetherist
« Reply #1049 on: February 06, 2022, 01:14:37 am »
AlphaPhoenix   I bought 1000 meters of wire to settle a physics debate.
1,334,747 views     Dec 17, 2021           6,827 comments.
I constructed the Veritasium electricity thought experiment in real life to test the result.
If you were watching my community posts a month ago, the day that Derek over on Veritasium posted his video about electricity misconceptions, you saw me obsess over that problem a bit too much and immediately use it as the excuse I've been looking for for years to own my own oscilloscope. Instead of two light-seconds of wire, I used about 3 light-microseconds of wire, but it was PLENTY to resolve exactly what is happening in this circuit. I hope you enjoy the analysis!
Thanks to Derek at Veritasium for his blessing to make a real-world version of his gedanken experiment. If you haven't seen his video yet, you might want to go watch that for context, and I also highly recommend ElectroBOOM's video on the topic and EEVBlog's video on the topic. Electroboom's video has some simulated scope traces extremely close to what I saw IRL, and a REALLY fantastic animation (8:27) of him waving an electron around in his hand, shedding magnetic fields as it moves (Even though I ignore magnetic fields in this video - I'm trying to think of a test to find out if they matter).
Veritasium https://youtu.be/bHIhgxav9LY
ElectroBOOM https://youtu.be/iph500cPK28
EEVBlog https://youtu.be/VQsoG45Y_00
Pinned by AlphaPhoenix  1 month ago (edited) COMMENTS AND CORRECTIONS:
CORRECTIONS TO THIS VIDEO:
The most important thing I believe I ignored in this video is the actual, physical distribution of charge in the switch-side wire while the current is starting up. How much charge travels AT the advancing wavefront and how much charge gets stuck along the wire in between the fuzzball I drew and the battery will depend on the physical size of the wires and how close they are to each other, setting their capacitance.
This charge distribution also DOES NOT look the same on both sides of the switch, although I drew it that way for simplicity.
In a later experiment (next video) my mind melted a bit as I measured the resistors on both sides of the battery and found the current going through them is different.
It doesn't change any of the logic I presented in this video, but it makes some diagrams less than perfect.
It's possible that cross-inductance between the wires contributes to the effect, using almost exactly the same diagram except the wires are connected by a magnetic field rather than an electric field. I couldn't figure out how to decouple these effects day-of, so I'm still thinking on how to test. Hopefully more to come there.
I'm sure there will be loads more - please leave comments about what I screwed up.
Veritasium reckoned that the Poynting Field would light up his bulb soon after 3.3 ns, & that it would shine brightly ever after (& 1 second later a bit brighter when the main current arrives).
AlphaPhoenix (Brian) mentions the Poynting Field at 11:40, but i think that Brian duznt care much for Veritasium's Poynting explanation for electricity. Brian merely said that his 1000 m X confirmed that Veritasium was correct that the bulb would turn on (& stay on) well before the main current arrived.
And Brian conceded that his 1000 m X could not verify Veritasium's 3.3 ns delay. Brian's switch he says takes over 20 ns to work (whatever that means). Brian is using a mickey mouse oscilloscope, ie only 100 MHz, which can't see finer than 10 ns.  He needs at least 1000 MHz, about $4,000. He can buy a used 20,000 MHz for $4,000, this can see 1/20th of a nanosecond.
Anyhow, Brian invented his own (unique i think) explanation for his early 0.2 V of current (which later climbed to 1.7 V). At 13:40 Brian says that when he flips his switch….
(1) His battery starts pumping electrons from one side to the other, & (2i) the negative wire gets a negative charge, & (2ii) the positive wire gets a positive charge, & (3) it creates a wave front of electrons pushing electrons along the negative wire, & (4) the pushing is modulated by photons of the em field which (5) travel at the speed of light, & (6) the pushing wave travels along the wire at approx the speed of light, which (7) creates a pocket of concentrated negative charge at the wavefront (going left), & likewise (8 ) we have a pocket of concentrated positive charge in the positive wire going right, & (9) electrons in the top (battery) wire interact with electrons in his bottom (bulb) wire, & (9) electrons sitting on the bottom wire near the bulb are free to move, & (10) they are pushed (repelled) & pulled (attracted) & pass through the bulb, giving (11) (not a lot of) current, but (12) it is almost immediate, (13) via the charge imbalance reaching across the air gap with electric fields, (14) without the far ends knowing. (15) Brian mentions two possibilities for the initial current at the bulb, (15i) capacitance tween the wires, & (15ii) inductance, & he says he will ignore inductance today, & he gives the above explanation for the capacitance effect. (16) Brian does not mention the Poynting Field or the Poynting Vector in his explanation.
My comments are as follows (here i am trying to explain Brian's ideas together with conventional ideas)(compared with my ideas)….
(1a) No. He does not have a battery, he has a 5 V DC source off his AC supply.
(1b) No. The 5 V does not start pumping when the switch is flipped, it is pumping all the time. Hence the negative wire already has a negative charge (across to the switch) before the switch is flipped, & the positive wire already has a positive charge (around to the switch).
(1c) If the end wires have been cut then the positive wire/charge must end at the cut. Which makes me wonder what the white trace would look like if that end was not cut & if only the left end was cut (i think the trace would look weird), & what would be Brian's explanation for the weird trace result (i think that he would have trouble trying to make his theory fit).
(1b again) The positively charged wire has a concentration of positive charge at the switch (the switch is a capacitor). And a concentration of positive charge near the bulb, in the length opposite the negatively charged wire (the wires are a capacitor).
(1d) Ok, now we flip the switch. Electrons already pushing on the switch now flow through the switch away from the -2.5 V terminal. After a short time this exit of electrons is felt back at the terminal, & electrons then start leaving the terminal, to replace the electrons going to & through the switch. A short time later this exit of electrons from the negative terminal is felt at the +2.5 V positive terminal, & electrons start entering the positive terminal from the positive wire. The 5 V source can't (initially) pump electrons at full flow because the positive wire is (initially) depleted (& to some extent the negative wire is initially over saturated). This shortage of electrons at the positive terminal will not be fully remedied until electrons have managed to flow from the switch around through the bulb & around to the positive terminal (ie 1 full lap of the circuit).
(1d) Indeed the green trace showing the voltage loss across the resistor near the positive terminal starts at zero volts & then slowly climbs gradually (in a lumpy way), & then does not reach its max voltage until a time corresponding to 1.2 full laps of the circuit. Brian says nothing about the green trace. His silly pumping idea should show the green trace starting at full current -- or more logically starting above full current, & slowly dropping to the steady full current as the distribution of charge along the wires reaches steady state, including the usual ups & downs due to any circuit related reflexions.
(4a) No. I reckon that an em field is not made of photons (not important today).
(5a) No. The em field does not travel at the speed of light. Or, yes, it does travel at the speed of light, but, the speed of light (& we assume the speed of em radiation) propagates at i think 10 m/s in copper (whereas i am sure that Brian assumes 300,000,000 m/s).
(6a) No. In view of (5a) above, how can the wave travel at almost the speed of light, or, yes, it might travel at the speed of light, but, the speed of light in copper is i think 10 m/s (whereas i am sure that Brian assumes 300,000,000 m/s).
(7a) No. In the light of (1abcd), Brian's pocket of concentrated negative charge starts at the switch not at the terminal. And, initially it is matched by a pocket of depleted negative charge starting at the switch & going to the terminal. And after it reaches the terminal there will be a new (small) burst of concentrated negative charge going away from the terminal. But, because the switch is close to the terminal, this complication is i suppose trivial.
(7b) No. Brian's concept of a pocket of charge at the wavefront is not realistic. The wavefront gives a leading edge, but the negative charge extends all of the way back to the terminal.
(7c) No. Brian thinks that he needs a pocket of negative charge well left of the bulb to repel electrons in the bottom wire to the right towards the bulb. A pocket of charge is not needed. Any kind of general distribution of negative charge in the top wire will repel electrons in the bottom wire, & common sense tells us that some of these will go right (for a while), no pocket needed.
(8a) No. We do not have a pocket of concentrated positive charge going right in the positive wire. Or, yes, we do, but, the green trace shows us that any such effect on the positive side of the circuit would be zero at first, & would take a long time to grow. But, the white trace does not show any evidence of that kind of growth. And, the pocket of positive charge is supposed to contribute say a half of the current through the bulb, ie a half of the white trace voltage, hence the white trace should definitely have growth (but duznt). Or, putting it another way, the green trace should not have growth (but it duz).
(7d) Similarly to (8a) if Brian showed us his trace for the resistor near the switch, i reckon that the current would have a quick spike & then fall, & after that grow in a similar fashion to the green trace.
(9a) Yes. Brian says that electrons sitting on the bottom wire near the bulb are free to move. Yes, it is the (conduction) electrons sitting on the surface of the wire (not in the wire) that are free to move. That is a key part of my own idea.
(10a) Yes & No. Yes, electrons are individually pushed (repelled) & pulled (attracted) & pass through the bulb. But, on the left half of the circuit, the overall charge in the top wire squeezes electrons out of the bottom wire, some going left (for a while), & some going right (through the bulb). And on the righthand half of the circuit the overall positive charge in the top wire attracts electrons in the bottom wire, & electrons near the bulb flow to the right (for a while), pulling other electrons through the bulb behind.
(11a) Yes. There will be some (not a lot of) current through the bulb, before the main current arrives.
(12a) Yes. The initial small current is almost immediate. However Brian's oscilloscope can't tell us exactly what happens in the first few nanoseconds, hence he can't actually answer the Veritasium gedanken question.
(15a) Brian mentions two possibilities for the initial current at the bulb, capacitance & induction. We could add radio as a separate class.
(15ia) Yes. Brian ignores inductance, because capacitance is the main culprit.
(15ib) No. Brian reckons that he explains the initial capacitance effect, but he duznt. His explanation has little resemblance to capacitance.
(16a) Yes. Brian quite correctly ignores Poynting in his explanation (unlike Veritasium who loves Poynting). Brian could have emphasized that Veritasium's Poynting explanation does not explain even one electron of what happens. Brian could have explained that Veritasium genuinely reckoned that there would be a very significant initial Poynting electric current. As it turns out there is indeed a significant initial current, but because of capacitance, not Poynting.
So, Brian's X pt1 did a good job, & we are all eager to see pt2. And me myself i want to see the trace for the resistor near the switch.
« Last Edit: February 06, 2022, 08:46:16 pm by aetherist »
