Thats going to be one hell of a diode to handle 72 amps.
put 72 nos of 1A rated diode in parallel
it happened i was about to reply just after nihaomike's post, but i have no strong reason for it... now, it was just a question of why do you want the mains power supply? why dont a battery? whatever... lipo? LAcid? mains psu is less portable
and you are going to need larger than normal ATX PSU (more expensive), at least 750W, i think it should be 1000W to take into account the loss factor, and if its 12V you are using. 22V? @ 72A? thats 1.5K++ watt! cray zee!
i think that one quadcopter can lift a man
