One possible explanation is that when your ut61e is doing resistance check, the auto range switching interfares with the inductive load. Likely (theoretically), this can happen only for load with particular values. A good test is to repeat what you did in the video, but with a scope attached to see the range switching. In the worst case (theoretically) the voltage may go reversed.
