For my 2c worth... (haha..)...
I fully understand that '
contacts' in ANYTHING, are not always just '
dirty', which certain solvents may help with.
The other main problem though is '
oxidization'. Being a 'ZIF" (Zero Insertion Force, with a Lever), there is no physical
'abrasion' either, when removing or re-inserting! (to actually 'scratch' itself clean).
One of my bosses years ago, once questioned what I meant in some of my site reports, about 'Bedding-in' some devices.
I explained about removing/re-inserting some parts, to friction-clean certain contacts, which often alleviated the problem!
With 'ZIF's though, this does not happen, so I would suggest repeatedly holding the ZIF Close-Lever
partially closed during
re-insertion, to cause some actual friction! It's only 'removal' that often needs minimal friction, having numerous pins!
