Time for the robot to get wet. It may already be in the water. The sonar data is on board I'm not sure if they have any real time info. The Navy has several of these but it appears that at least two are on site. No mention of the search pattern but that would be interesting. Expected coverage is 40 square miles per day.
Here are the details from the US Navy (Naval Sea Systems Command)
http://www.navsea.navy.mil/SitePages/TPL25_bluefin21_faq.aspxBluefin-21
Q. What is the Bluefin-21?
Bluefin-21 is an autonomous underwater vehicle (AUV) that can be equipped with either a side-scan sonar or a still camera to gather underwater data. Bluefin-21 is 16.2 feet long, has a diameter of 21 inches and its dry weight is 1,650 lbs. Its depth rating is 14,763 feet and has a maximum speed of 4.5 knots. Its mission endurance is 25 hours with standard payload at a speed of 3 knots.
Q. How does this system work?
Technicians program the Bluefin AUV to search a specific area before the vehicle goes in the water. During the search, the system uses a side-scan sonar or a still camera to gather data. Once an area search mission is completed, the AUV is removed from the water and plugged into a processing suite for data download. The data is then analyzed. While data is being analyzed, a subsequent mission may be programmed and the AUV may be deployed to perform its next area search.
Q. How much ocean can be covered by the Bluefin-21?
The effective range of a sonar device and therefore the Bluefin-21 is dependent upon a number of factors. These factors include the water depth within the search area, the contours of the sea floor, and the size of the material being searched for. Therefore it is not possible to provide a standard maximum range for the side-scan sonar/Bluefin-21. However, as a rough estimate, the Navy expects to be able to search approximately 40 square miles per day using the Bluefin. This estimate will be affected by the specific environmental factors encountered.
