Congratulation, looks like its still in a really nice condition.
EDIT: 1 set each of Probe Master 8044S and 8018S to compliment the new bench DMM...good enough for government.
Looks like those probe's banana jacks are shrouded, you might need to cut those plastic shroud.
At mine, I love to use the banana to bnc binding post like this here ->
ClickCongratulations! Just beware that series uses a 10 year Li backup battery to store calibration data; when it goes so does the cal. You may want to serious consider replacing it before it goes.
As above saturation's concern, if you're going to replace that battery, please share and make a new thread for it, I might join you as well replacing mine, although last time I did measure it, the batt's voltage still fine.
