Author Topic: Torx bit recomendations  (Read 4572 times)
Offline Kjelt
Re: Torx bit recomendations
« Reply #25 on: May 22, 2018, 12:27:30 pm »
Only problem is that im also very good what comes to loosing bits all over my yard.
Blame the bitholders, or they have a loosy fit and bits keep missing, or the fit is so tight you almost need to wear gloves to get the bit out.
I prefer the first option , that is why I loose bits in my garage behind or under all kind of stuff. Last year I tore down a cabinet and found a lot of bits under it, all rusted unfortunately.
Hey that is why I recommend the cheaper boxed versions, you get 5, 10 or even 25 spares to last you till the end of the year  :D
Before someone claims I am sloppy, my drills in a 60 piece drill set are after 5 years still complete, and for my precision screwdrivers like the Wiha's also all complete.
It really are the bitholders and probably the cheapness of the bits that make them disappear.
« Last Edit: May 22, 2018, 12:31:16 pm by Kjelt »
Online Monkeh
« Reply #26 on: May 22, 2018, 03:53:55 pm »
Haven't lost a bit yet despite twisting screws around them and abusing the poor thing with an impact driver.
(it's a Bosch holder, sorry, couldn't find an image with the label)
E: There we are:
Don't leave home without it. Other sets available. Price may induce tears.
« Last Edit: May 22, 2018, 03:56:48 pm by Monkeh »
The following users thanked this post: Kjelt
Offline JaspaJami
    • Susijarvi
« Reply #27 on: May 23, 2018, 06:01:59 am »
Yep, i also normally buy cheaper one. 25 pieces of T20, T25 and T30 and they last for summer
Offline VgkidTopic starter
« Reply #28 on: May 24, 2018, 05:42:23 am »
Thanks for the replies , I will keep using my dewault ones , until they get lost. :scared:  :palm:
I usually use a drill , anyone used them in a cordless impact?
