We all know the law. Energy can not be created nor destroyed. In a closed system, the enegy going in must be equal (in a theretical lossless circuit) or less than the energy coming out due to losses.
And in no way can energy output be greater than the energy input.
Well, I am here to open your mind.
What is the calculation of energy?
Time x Watts? Thats about it right. So, here is the thought experiment.
Let's say we have a solar powered satalite that is orbiting the earth. The solar power is charging a battery that provides the power output. The battery is fully charged and has a very long life, so the charge will not drop under load.
The satalie is tetherd to the surface of the earth AT AN ALTITUDE LESS THAN 1/2 the distance of the radius of the earth (200 miles) by a theortical room temperature superconductive conductor.
The satalite's battery powers a load that is on the surface of the earth via the RTSC wire.
The relative time of the satalite is slower than the relative time on the surface of the earth due to time dilation from gravity.
(lets say 1 second every century)
If the battery is suppling power to a load constantly, the CALCULATED energy supplied to the load at the surface of the earth is GREATER than the CALCULATED energy that is being transmited by the battery.
Boom!
That's the sound of your head exploding.
