Author Topic: Those old cardboard sleeved slide-charts !!  (Read 6630 times)
Offline GlennSpriggTopic starter
  • Medically retired Tech. Old School / re-learning !
« on: May 15, 2020, 01:09:30 pm »
I love those old nostalgic slide-charts! I've found some like this one that is a "Shure Reactance Slide Rule". This is just a greatly reduced image of just the Outside-Front, (although I'm editing the precise alignment & graphics fixes for the back, & inside 'Slide' too!! ).
I'm creating accurate .PDF files, so as to Laser Print your own, with quality Photo-Grade paper/cardboard. I will shortly make the full files available, with instructions, as these 'Slide-Cards' are becoming extremely hard to come by now!!
There are some that I can't find that would be fun, and useful !!!....
The Allied Radio Coil Winding Calculator...
The Ohmite Capacitor Calculator...
The RCA 'Pindex' Valve pinout chart...
Those are just small pics, but What I'm after, is SCANS of the INNER SLIDING SLEEVES !! if anyone has those 'Cards' !!  :D
I will gladly supply all completed detailed Documents for printing, with instructions, when I'm done...  :-+
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
The following users thanked this post: cdev, CatalinaWOW, tpowell1830, schmitt trigger
Offline DrG
Re: Those old cardboard sleeved slide-charts !!
« Reply #1 on: May 15, 2020, 01:24:35 pm »
- Invest in science - it pays big dividends. -
The following users thanked this post: cdev, GlennSprigg
Offline TerraHertz
    • It's not really a Blog
« Reply #2 on: May 16, 2020, 11:28:58 am »
Cool. I collect these sliding cardboard calculators too. Though it's a very modest collection so far.
Like you Glenn, I want to make them functionally available to all for free.
However I suggest your PDF printable versions are not the best way to do that.
For one thing, PDF sucks for this. None of the internal image encoding schemes available in PDF are adequate.  The choices are: BMP (vomit), JPG (lossy, horrible edge artifact noise), 'FAX mode' (appalling), JBIG2 (the people that came up with that scheme should be shot.)  Hmm... I'm forgetting one? TIFF?  Also, printing dimensionally accurate images on home printers? Hadehaha.
Anyway there's NO equivalent of PNG in PDF. Surprisingly few people realize this. Most PDF creation utils can accept PNG images, so people just assume the resulting images in the PDF are still PNG. Nope. Try zooming on the result - you will see typical JPG edge noisy crap. It converted the PNG to JPG, because THERE IS NO PNG in PDF. Look up the PDF standards if you don't believe me.
And given that the PDF standard is now controlled by the useless money-grubbing parasites of the ISO, there never will be.
Hence everyone scanning historical technical documents into PDF is wasting their time, and producing mostly garbage. That will one day have to be scanned from scratch all over again once we have a decent document preservation file format. Minus the documents that no longer exist, because people destroyed the last copies while scanning to make those awful PDF insults to the original author's efforts.
What I'd like to do with the few slide charts I've gathered, is scan in high res PNG (not a problem), then wrap the images in  html & Javascript code to achieve a functioning virtual copy, that works in any web browser.  Bundle as a downloadable zip, so anyone can have their own working slide charts, without having to mess around with printers, guillotines, etc.  Also, rivets. Some of them use rivets to make slide guides, and those would be a pain to obtain and DIY up to the original standards.
The following users thanked this post: GlennSprigg
Offline Synthtech
« Reply #3 on: May 16, 2020, 01:29:36 pm »
Pretty sure I have the entire Shure reactance slide rule kit including manual. I will take a look in the morning.
The following users thanked this post: GlennSprigg, WattsThat
Offline DrG
« Reply #4 on: May 16, 2020, 02:34:08 pm »
Making them "virtual" is compelling. This has been done quite a bit with slide rules and I think the results are impressive.
http://www.antiquark.com/sliderule/sim/n3t/virtual-n3-t.html
http://solo.dc3.com/VirtRule/160es/virtual-160-es.html
Even free software to assist with the chore (no idea if it works well).
https://www.animatedsoftware.com/elearning/DigitalSlideRule/index.html
Offline TimFox
« Reply #5 on: May 16, 2020, 04:54:33 pm »
Many of these classics were manufactured by the Perry Graph Co. as advertisements for the well-known companies.  The company still exists:  https://www.americanslidechart.com/
but most of the examples shown on their current website are just tabular:  the interesting old ones included actual logarithmic slide rules for calculating reactance, etc., instead of just look-up tables.  They seem only to print these for company orders, with no generic units in stock.
Offline Synthtech
« Reply #6 on: May 17, 2020, 06:08:05 am »
I dug this up this morning. The full kit.
Offline TerraHertz
« Reply #7 on: May 17, 2020, 12:26:24 pm »
This is most of my collection.
Partial list:
Pulsed RF Calculator.  By HP  (not in photo)
  Comes in pocket of HP App Note 150-2 - Spectrum analysis.... Pulsed RF.  Nov 1971.
Capacitance - inductance - Reactance calculator.  By HP
   Vector Impedance calculator.    Suits HP 4815A Vector Impedance Meter.  1971
Reflectometer calculator, and flip side: Mismatch error limits calculator.  By HP
   I have 2 of these, slightly different.    Older one is 1967. Newer one is 1976
Boonton Electronics Slide Rule for Reactance + Q + Dissipation Factor
ARRL L/C/F Calculator Type A & Single-Layer Coil Winding Calculator
Bell Telephone Laboratories Resonance Computer Designed by G. R. Frost
The following users thanked this post: Alex Eisenhut, schmitt trigger, GlennSprigg
« Reply #8 on: May 18, 2020, 12:48:15 pm »
Thank you ALL for your replies!!!
I'm re-processing your replies over the next few days.....  Thank you!
« Reply #9 on: May 18, 2020, 12:54:00 pm »
I will be following up shortly!.... but in the interim, I'm confused why a .PDF (with detailed enough scalable graphics) would not print 'perfectly' ??
Offline tom66
« Reply #10 on: May 18, 2020, 01:08:49 pm »
PDF supports RLE image compression.  It also supports post-document compression, or you can zip the document yourself.  Recall that PNG is LZ77 with an image predictor.  Zipping a BMP, while not quite as good as PNG, is not too far off.
And we live in a day with 1TB SSDs for under $150 USD.  Storage is cheap, and so is bandwidth.  Hardly the biggest pain.
« Reply #11 on: May 21, 2020, 12:43:20 pm »
Have you seen this guy's site? https://stevenjohnson.com/cardboard/slidecharts.htm
Thanks to all for your current responses. To 'DrG'...
Yes!, and that's where i have got most of my 'Outer-Front' images from!!
The problem is finding images of the 'Inner-Sleeves' themselves!
One of my 'specialties' is graphics/artwork, and so I have no problem with totally editing the graphics, removing scan/photo imperfections, adjusting perspective/size, contrast/brightness/colour, and accurate scaling of the components. (A work of love! haha... ;D)
To 'TerraHertz'...  You might be missing something?  Of course the detailed results depend on the 'lossless' characteristics of the image data that I am using, and am recreating them with, before compiling the final '.PDF' files. I've been doing graphic design for many years, for the likes of Logos, product design packaging/printing, and ALL the printing companies want/use .PDF files sent to them. The only other requirement is whether images are either in RGB or CMYK depending on the printing process. This isn't a problem here, as what I'm producing is something that people at home can print on their Inkjet/Laser printer. Everything scaled, and includes instructions.
It's actually simpler than might be imagined!!  For instance, I'm deliberately NOT using double-sided printing, as for instance, the 2 sides of the inner slide  are to be printed on the thickest paper your printer can handle, and then glued back-to-back, to make it more rigid and 'cardboard' like, as in the originals.  And the 'Outer' front/back will have a small folded flap, before gluing/stapling, to account/allow for the inner sliding sleeve!  WAIT until I supply that first one, and all will be clear!   :-+
Offline Neomys Sapiens
« Reply #12 on: May 21, 2020, 03:32:38 pm »
I'll try to dig mine out and have them ready when I will go to the office again. I guess that placing them on the scanner/copier would be more interesting than fuzzy handheld shots with a digital camera.
Offline Alex Eisenhut
  • Place text here.
« Reply #13 on: May 21, 2020, 05:30:13 pm »
The following users thanked this post: TerraHertz, Neomys Sapiens, GlennSprigg
Offline bsfeechannel
« Reply #14 on: May 21, 2020, 08:15:50 pm »
This is my modest contribution. I have it since donkey's years.
Translation
IDENTIFICAÇÃO DINÂMICA DE TRANSISTORES = TRANSISTOR DYNAMIC IDENTIFICATION
X - NÃO EXISTE = X - NON EXISTENT (I.E. NO TERMINAL)
1 - LIGADO À CARCAÇA = 1 - CONNECTED TO CASE
USO GERAL BF = GENERAL PURPOSE LF
BAIXA POTÊNCIA RF = LOW POWER RF
POTÊNCIA = POWER
COMUTAÇÃO = SWITCHING
LETRA INICIAL = INITIAL LETTER
A - GERMÂNIO = A - GERMANIUM
B - SILÍCIO = B - SILICON
The following users thanked this post: rsjsouza, Alex Eisenhut, GlennSprigg
Offline TerraHertz
« Reply #15 on: May 22, 2020, 03:55:32 am »
https://datasheet.datasheetarchive.com/originals/distributors/Datasheets-21/DSA-419096.pdf
It says designed by Jim Mears
Thanks for mentioning that. I hadn't heard of it. And... I found one on ebay immediately and cheap.
As for the Nat. Semi. AN 905, hmm... I wonder if the PDF is as published by NS, or a product of scanning and OCR? It's fairly good, but I think a little off in the fonts.
Nat Semi was bought by Texas Instruments in 2011. Is it still possible to buy paper copies of back-issue ANs from some part of TI? Or do I need to hunt an old copy online?
Do you have something like a guideline from a printing company, specifying the structure of PDF files to send them for printing jobs? I'd be very interested to see that.
I'm also looking forward to your first printable cardboard slide rule file.
« Last Edit: May 22, 2020, 04:08:18 am by TerraHertz »
  • Place text here.
« Reply #16 on: May 22, 2020, 02:09:01 pm »
Well for my Rapidesigner I just scanned them in. Not as interesting as you think, now you have fuzzy high resolution scans with artifacts.  :-DD
https://drive.google.com/open?id=1XSHg6Vu-p49l1W5CH5dboN9JmgSXw73r
It's a zip that I call piz because Google always complains about zip files IME.
Don't know, but I'm pretty sure I had the Nat Semi databook CD set back in the day, and I copied them somewhere. In any case, doesn't PDF render with your system's fonts?
  • Place text here.
« Reply #17 on: May 22, 2020, 02:27:54 pm »
I just found this on my desk. Yes it's a messy desk...
« Reply #18 on: May 23, 2020, 12:15:46 pm »
I am thrilled with everyone's responses !!
EVERYTHING all have posted has been saved, and I'm working on the 'project' as we speak!!
Thank you all !! Within a few days, I'll have the 1st result. Hopefully we will all take it from there!!   :-+
« Reply #19 on: May 23, 2020, 12:21:14 pm »
(Attachment Link)
Translation
POTÊNCIA = POWER
This is a pretty good example of what I want. (Scans, not just photos??)
I can graphically correct every aspect of those images, and re-create the whole thing.
I love the nostalgia of such things, and have the ability to re-create it!
Offline Tomorokoshi
« Reply #20 on: June 12, 2020, 12:30:06 am »
This Measurement Error Calculator from Hewlett Packard oscilloscopes can be used to perform many useful calculations. It includes a basic slide rule. For instance, I can now easily calculate that 10 / 2 = 4.97.
« Reply #21 on: June 18, 2020, 09:04:20 pm »
First, one specimen which is completely in accordance with the title of the thread: A Rotring (manufacturer of drawing supplies) slider intended as a general aid for maths and geometric calculations:
1004606-0
1004594-1
1004596-2
Then two circular application-specific slide rules.
A BBC (Brown Boverie & Cie.) electrical calculation slide rule, of which one side is dedicated to squirrel cage three-phase motors and their Power, voltage, current, and pole count/speed relationships. The other side is for power factor calculations, i.e. to determine the size of compensation capacitors.
1004598-3
1004600-4
And a Trilux lighting calculator which helps the user to determine the number of lamps which are needed to achieve a certain illumination over an area taking into account their efficiency. (Rear is for room factor, which is a auxiliary quantity which goes into the beforementioned calculation).
1004602-5
1004604-6
The latter two exhibits are not cardboard and I would not call them slide-charts bur rather circular slide rules, but the might be of interest to the readers here.
« Last Edit: June 18, 2020, 09:05:55 pm by Neomys Sapiens »
Offline CatalinaWOW
« Reply #22 on: June 18, 2020, 09:56:28 pm »
I have a couple that might be of interest.  But when I went to where I thought they were stored I found no joy.  I'll keep looking and post when I find them.
Offline TerraHertz
« Reply #23 on: June 20, 2020, 02:38:19 am »
This Measurement Error Calculator from Hewlett Packard ...
I love ebay!
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #24 on: June 20, 2020, 07:23:38 pm »
I used it a lot when I was a kid. I think I still have this one with me somewhere.
