Author Topic: Will This Transformer Do For Tool Purchased In USA?  (Read 19792 times)
Offline Boris_yoTopic starter
  • Country: il
Re: Will This Transformer Do For Tool Purchased In USA?
« Reply #50 on: April 11, 2012, 11:42:03 am »
Those "compact" things are just glorified light dimmers . It's been said before .
Right, but manufacturers must state so because i hear a lot of people constantly running into shocks, fires etc. as they are misled. In fact people are being misled because seller wrote in description that this "dimmer" (2nd link) fits DeWalt charger.
What do you think about used charger by the way (3rd link)? Worth the risk? eBay does not offer life insurance yet by the way.
« Last Edit: April 11, 2012, 11:46:40 am by Boris_yo »
Offline T4P
  • Country: sg
    • T4P
« Reply #51 on: April 11, 2012, 11:47:09 am »
Right, but manufacturers must state so because i hear a lot of people constantly running into shocks, fires etc. as they are misled. In fact people are being misled because seller wrote in description that this "dimmer" fits DeWalt charger.
What do you think about used charger by the way? Worth the risk? eBay does not offer life insurance yet by the way.
Used charger ... err ... hurr ... durr ... that seller has 99% rating
Offline G7PSK
  • It is hot until proved not.
« Reply #52 on: April 11, 2012, 12:38:40 pm »
Those things are only good for resitive loads for a minute or two like hair dryers and shavers etc. Your charger is either an inductive or capacitive load, I have one of those things that I bought when visiting the US as a curio and it is not much more than that. You must either get a European charger or a proper transformer or bin the power tool any thing else is asking for grief.
Offline T4P
  • Country: sg
    • T4P
« Reply #53 on: April 11, 2012, 05:30:45 pm »
It's a switching supply inside so the 200W only lasts for milliseconds while the Low ESR Caps charge up .
  • Country: il
« Reply #54 on: April 11, 2012, 06:24:44 pm »
Can you explain please? Is that good or bad in your opinion? I have seen sellers with 92% rating but compared to them, 99% is almost perfect.
Offline T4P
  • Country: sg
    • T4P
« Reply #55 on: April 11, 2012, 07:18:42 pm »
Go ahead and if anything goes wrong do the paypal thing .
« Reply #56 on: April 11, 2012, 07:53:04 pm »
The power supply is a simple step down converter, using an output that is connected directly to the rectified mains input. Best is to use an isolating transformer, the site transformers are common enough in Europe on work sites, so these will do the job. Voltage converters will make a lovely smoke generator.
Offline T4P
  • Country: sg
    • T4P
« Reply #57 on: April 11, 2012, 08:05:40 pm »
No .
http://dewaltownersgroup.com/index.php?topic=869.0
A site transformer is an extra load , he'd better get a used 220V dewalt charger instead .
Online IanB
« Reply #58 on: April 11, 2012, 08:18:29 pm »
The site transformer will be more generally useful for any other 120 V items that may also need power. The 220 V DeWalt charger would be more compact, but will be confined to just the one use.
Offline G7PSK
« Reply #59 on: April 11, 2012, 09:00:05 pm »
If you go round the larger building/construction sites you may be able to pick up a site transformer for free or a drink, many of them get condemned by the site safety officer due to the spring loaded socket caps getting knocked and broken nothing wrong with  the transformer but no socket cap and they get slung into the skip.
Offline T4P
  • Country: sg
    • T4P
« Reply #60 on: April 12, 2012, 08:43:02 am »
Certainly yes . Big 'n heavy and he can put a heck more things then just a dewalt charger .
