... Fluke should still honor the warranty assuming the guy gives you a receipt.
If the meter comes with no receipt I would look somewhere else.
If the seller I quoted in my earlier post is correct, then that isn't sufficient - just having a receipt won't do - you need a receipt from an "Authorized Fluke Dealer" showing the serial number.
I'd like to get an official answer from Fluke. I've purchased new, in the box, meters before, but, thankfully, have never needed the warranty.
Another thing many people don't know is that Fluke's "lifetime warranty" isn't YOUR lifetime, it's the "lifetime" as defined by Fluke. From Fluke's website:
Industrial Products Limited Lifetime Warranty
Lifetime is defined as seven years after Fluke discontinues manufacturing the product, but the warranty period shall be at least ten years from date of purchase. *(Lifetime Warranty applies to products manufactured after October 1996). The warranty does not cover manuals, fuses, disposable batteries, damage from neglect, misuse, contamination, alteration, accident or abnormal conditions of operation or handling, including failures caused by use outside of the product's specifications, or normal wear and tear of mechanical components. This warranty covers the original purchaser only and is not transferable. This warranty covers the LCD for 10 years only (state-of-the-art for LCDs). To establish original ownership proof of purchase is required. (20, 70, 80, 170, 180 and 280 models)
